Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Grease that's universal on ALL aspects of car care
by NattyBoh
07/24/16 09:45 AM
Oil made from natural gas?
by Sealbilly
07/24/16 09:18 AM
Rotella line upgraded
by Sealbilly
07/24/16 09:13 AM
Kendall VersaTrans LV for Toyota WS?
by Slick17601
07/24/16 08:03 AM
Clutch problem
by chrisri
07/24/16 07:49 AM
Peppers: do you grow them?
by car51
07/24/16 07:29 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
84 registered (alanwayne1908, AirgunSavant, 41 Plymouth, 182RG, Al, AlienBug, 8 invisible), 2043 Guests and 14 Spiders online.
58578 Members
66 Forums
252188 Topics
#3182975 - 11/09/13 12:58 PM Do any of these need replacing?
llmercll Offline
Loc: ny
I'm relatively new to car maintenance and am not sure how to tell if my air filter or o2 sensor needs replacing. Typically if the air filter is dirty I would replace it, but this is a k&n and is red, so I'm not sure what I'm looking for.
http://imgur.com/PaZmXGr
http://imgur.com/Bs7bOAM
http://imgur.com/44jqKZI
http://imgur.com/gDoYiSH
any input on the state of mine or what i should look for in the future is very appreciated,
thanks!
#3182978 - 11/09/13 01:07 PM Re: Do any of these need replacing? [Re: llmercll]
danster Offline
Loc: Nebraska
The air filter is fine. It doesn't look like it is even ready for cleaning. When you do clean in in another 20,000 miles use the cleaning and re-oiling kit available from K&N.
The O2 sensor looks fine but I don't think you can go by looks. Most manufacturers have a replacement interval based on mileage or you can measure the output with a VOM on a running car.
Edited by danster (11/09/13 01:08 PM)
#3182982 - 11/09/13 01:16 PM Re: Do any of these need replacing? [Re: llmercll]
Donald Offline
Loc: Upstate NY
I am not a fan of K&N. I would replace it with a high quality media filter. Your engine will ingest less silicon.
As for the O2, if its an upstream, then roughly ever 100K replacement. If downstream, wait for a code.
If you do replace the O2, either get an OEM or the same company that made the OEM,
Edited by Donald (11/09/13 01:17 PM)
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3182985 - 11/09/13 01:21 PM Re: Do any of these need replacing? [Re: llmercll]
llmercll Offline
Loc: ny
thanks guys, i didnt even know the k7n was replacable, i thought all air filters were disposable. looks like my car came with a real nice air filter from a few google searches.
as for the o2 sensor, downstream means after the cat, upstream means before, right?
thanks!
#3182987 - 11/09/13 01:22 PM Re: Do any of these need replacing? [Re: llmercll]
Trav Offline
Loc: MA, Mittelfranken.de
How many miles on the O2? There are two schools of though on O2 sensors. Some say change it when it throws a CEL others change them as a maintenance item.
I change them out at 100-125K, they do get lazy and are probably not performing optimally at about that mileage.
Filter looks fine if you like K&N.
#3182989 - 11/09/13 01:24 PM Re: Do any of these need replacing? [Re: llmercll]
bigjl Offline
Loc: London, England
If the OP is happy with a K&N why comment about changing it?
I expect if you replaced it with a piece of wood it would stop even more silicon.
Air filtration is not an exact science.
There is always a compromise between the best possible filtration and flow being reduced so that performance is affected
I will post up pictures of the air filter in my XJL which would appear to have been the factory fitted one, 90k round London in two years!
It would certainly have been filtering well as not much would hsve been getting through.
But it did 27mpg for the first 1000 miles i did and over the last 1200 it has done 37mpg, i did do more out of town usage but not enough to explain that difference.
The DPF light has also not come on since and the vehicle is much happier driving round town.
If the OP is happy then it is all good in my book.
I certainly would be happy to leave that filter another 10k before rechecking and even considering a clean and reoil.
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3182994 - 11/09/13 01:28 PM Re: Do any of these need replacing? [Re: llmercll]
Donald Offline
Loc: Upstate NY
thanks!
K&N's claim to fame is that it does not restrict the flow of air and you can clean and re-oil it. In practice I do not believe a clean air filter restricts air much more than a K&N. But people with UOA who use a K&N usually see more silicon in the oil (from the air). There is also some concern that people over-oil the filters after cleaning and it messes up the MAF sensor.
#3183012 - 11/09/13 01:48 PM Re: Do any of these need replacing? [Re: Donald]
Chris142 Offline
Loc: apple valley, ca
x2
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3183029 - 11/09/13 02:17 PM Re: Do any of these need replacing? [Re: llmercll]
andyd Offline
Loc: Marshfield , MA
A fellow I know has a 535i, the E28 version, with 500K miles on it. He taps the paper element on his shoe every so often. Air filter and fuel filter change intervals are very much dependent on conditions.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3183040 - 11/09/13 02:39 PM Re: Do any of these need replacing? [Re: llmercll]
Warstud Online   content
Loc: MIchigan
I don't consider them a maintenance item. A CEL or bad gas mileage is the only time I change them. On some vehicles an 02 can cost $100 or more.
OP...don't forget some anti-seize on it before you put it back on.
