Hi
I started out reading the Subaru Oil Pump Specs as Relates to Filter Bypass thread, and I got lost around page 3. I am interested to know what the overall conclusion was or what the apposing views were.
If matching up an aftermarket filter would you stick with the OEM by-pass pressure or will it make little difference?
I ask as one of my cars also has a 23psi bypass valve. I have noticed some filter manufacturers list a filter with the 23psi bypass pressure and also offer an alternative filter with a different pressure valve. One manufacturer lists a much larger filter with a lower bypass pressure. I'm guessing it must be able to cope with a higher flow rate so the bypass valve can afford to be set lower. Is this thinking correct?
