Originally Posted By: ruskas
Hi, usually the viscosity for these types of compressors is ISO VG150. what would be the cases of using a ISO 220? or higher? majority of compressors oils the manufacturers do not allow ZDDP or similar anti wear additives.
the compressor is an API618 machine, up to 250bar, only last stage piston gives problems.
How would i performed the calculation? any references?
Regards
Quote:
Unless you know how much blowby gas in ppm gets past the rings on each stroke there is no way to determine the concentration.
As I stated above. Perhaps the manf. would know but I doubt it since much depends on the ring wear, cylinder compression, and valve sealing which would in turn affect compression.
A specialized oil analysis might be able to determine the amount of gas intrusion as a function of TAN increase.
The only other option for excessive blowby is re-ringing and cylinder honing.
