Originally Posted By: cheesepuffs
Originally Posted By: KCJeep
Please do post we never get tired of looking at gutted filters.
I won't use an ecore and I don't consider myself a filter "snob", I'll use an orange can on the right application without hesitation.
My buddy at work actually lost an engine to a failed ecore that came from a Firestone. Sure we all heear internet horror stories, but I don't know one single other person in real life that has lost an engine to a filter except him. (In Champ's defense they did replace the engine and were very good about it too.)
I tried an ecore also, as I can't help but experiment. It made it 6 days, start up rattle was so bad even though it was summer I had to take it off. Examination after only a few hundred miles revealed pleat flattening already occurring, which is the precursor to blow out on the ecore.
I was using the STP S8 filter.
Filter anxiety is back...
I do feel like my oil pressure takes slightlyyy longer to rise, but I'm attributing that to the suddenly significantly colder outside temps here.
It's probably the cold weather - the gauge itself is probably more sluggish in cold weather. With a positive displacement oil pump, the oil filter should not effect the oil pressure unless the oil pump is in pressure relief. Are you seeing like 70~80 PSI right after start-up? If not, then the pump is most likely not in pressure relief.
