Im going to change the plugs on my LS1. Gm has changed the Ac-Delco part numbers for plugs so much since 2000 im not sure which plugs to use. I bought 41-962 platinum plugs, but some are suggesting using Copper NGK TR-55 plugs for the best value/performance. others buy expensive Iridium plugs. The plugs in the car now are Ac delco 41-952 which i don't think exist anymore.
should i switch the the TR55's for 1.99 each and change them every 30k or keep the platinums i have purchased? What do you LS1 guys recommend? the car is bone stock, all the way to the air filter. thanks!
-Donny
-Donny
