Decided to dust-off (literally) my old 30+ yr. road bike. Now cleaning & regreasing the loose BB hubs. Already done the front. On the rear, I'm not sure how to tighten the bearing cone against the outer nut to 'jam' it into place like I did on the front hub. The bearing cone is down inside the freewheel, so it's not accessible after inserting the plastic bearing shield, the shiny aluminum spacer and the outer nut.
Then again...maybe I need to 'jam' the freewheel side, insert the axle, and adjust the opposite side where I have good access to both the cone and the outer nut. Is this correct?
I can post pics....
I can post pics....
