Originally Posted By: Odysseus2010
Noticed at Advance Auto a display for Pure One and the Bosch Distance Plus - they seem to filter the same size particles but the display says the Bosch holds more grams of contaminants than the PureOne. Costs twice as much too and weighs twice as much. Is this a meaningful real-world advantage or just marketing hooey? I am switching to syn (probably Ultra or M1 EP) and want a filter that can last for an extended drain. Advice, observations, what do y'all think?
In a known clean engine those numbers mean the Bosch can go 20000 miles or more. I run standard filters 10000 miles. Those long life,extra capacity ones are capable of drains I'm sure no one here will even run to their useable half life.
A standard classic will do 10000 miles for 4 bucks. Use it as your value point. Are you gonna run an 8 dollar filter twice as long,if not don't spend the extra money.
Dnewton has already proved a puro Classic can run out to a 15000 mile drain and it was still filtering as designed with no sign of accelerated by-pass events nor were his insols high. Quite the opposite actually.
