Originally Posted By: bluesubie
American Honda settles class-action suit over oil-burning claim
DETROIT -- American Honda Motor Co. has agreed to settle a class-action lawsuit over claims that it manufactured 1,593,755 defective vehicles that excessively burn oil and require frequent spark plug replacements.
The settlement concerns all U.S. purchasers and lessees of 2008-12 Accord, 2008-13 Odyssey, 2009-13 Pilot, 2010-11 Accord Crosstour and 2012 Crosstour vehicles equipped with six-cylinder engines that have variable cylinder management. Accord vehicles with four-cylinder engines are excluded from the settlement.
http://www.autonews.com/article/20131022/OEM11/131029975?template=mobile&X-IgnoreUserAgent=1
Edit: I just noticed this settlement exludes VCM cars. Is this a different problem??
-Dennis
Wow-I knew they had problems but no idea how many cars were involved.
This from www.driveaccord.net:
Andrew Thurlow's summary of this case (above) is misleading with regard to what the
proposed settlement order actually says.
It is important to note the scope of the proposed settlement. Namely: "This lawsuit is about Engine Misfire and its symptoms and causes . . . . The Engine Misfire at issue generates one or more of the following vehicle diagnostic trouble codes (“DTC”): P0301, P0302, P0303, or P0304." Significantly,
the proposed settlement does use or mention the words "oil consumption" anywhere in the proposed settlement order. Thus, unless the claimant's V-6 experiences a "diagnosed" "engine misfire" that results in one of the DTCs listed in the proposed order, the fact that the engine may consume "x" amount of motor oil per thousand miles is not relevant and is not included in the PSO.
Thurlow also failed to note that (quoting from the PSO): "
The Court has not decided in favor of Plaintiff or Defendant. Instead, both sides agreed to a settlement on behalf of everyone in the proposed Settlement Class . . . . Settlement Class Members will only receive certain agreed-upon benefits "if the settlement is approved and becomes Final." That determination will not be made until March 21, 2014.
What are the proposed benefits for claimants? Good question. Here again, it's important to read the PSO for content. If the PSO becomes final, the "remedy" for "qualified Engine Misfire" may include repair or replacement of spark plugs, valve stem seals, and engine pistons and/or pistons rings." The PSO further states: "[L]ess commonly performed [repairs] . . . may include repair or replacement of ignition coils, the engine short block, the engine long block, and the valve timing chain and/or valve timing tensioner." Finally, "Out-Of-Pocket Expenses for services are eligible for reimbursement only if the repair invoice or other documentation indicates that they were performed in connection the following diagnostic trouble codes (DTC) P0301, P0302, P0303, or P0304."
