I was doing some digging on power steering fluids, and it looks like Pentosin CHF202 has superseeded the [old] CHF11S.
Only significant difference I see is that 202 is a touch thicker at very cold temps (-40 C) and hence has a slight drop in viscosity index. Pour point is also down a bit too, but the ignition point has risen.
I have no doubts that it is totally safe to use, but I'm just curious if dealers and indie shops are making the switch. Oddly the CHF202 carries fewer manufacturer specs but I suspect that's because it's new enough that it hasn't been thoroughly tested.
For those curious...
CHF11S technical datasheet:
http://www.pentosin.net/pressreleases/CRP-116_Pentosin_CHF11S_V3.pdf
CHF202 technical datasheet:
http://www.pentosin.net/specsheets/Pentosin_CHF_202.pdf
