Originally Posted By: Finn
The 5W-30 is even still a bit "obsolete" over here ie. there are several 0W-30/40 and 5W-40 oils available but not that many 5W-30 oils. The genuine GM 5W-30 and Ford 5W-30 are available and some other A1/B1 oils. Then there is Castrol but they are expensive.
In absense of reasonably priced quality 5W-30 oils would M1 0W-40 or the Shell Helix Ultra 5W-40 be OK or should I just try to swallow the higher price of 5W-30 oils?
I certainly wouldn't use the word "obsolete" to describe the 5W-30 grade, limited availability would be a more apt description.
If you can find a A5/B5 0W-30 that's more affordable that would be an ideal choice. Failing that, are there any reasonably priced 0W/5W-20 oils available? If so then you could blend your own light 0W/5W-30 grade.
