236K on the Blazer. PO said the 350 was rebuilt approximately 40K ago.
Got it out for a test run on the highway to break the gears in... Parked it and noticed it started to spew coolant from the back passenger side of the block area. First I thought it was a core / freeze plug but after pulling the starter it was not. Started it up and the best I can tell is it's coming from up behind the block. My thought now is possibly the intake manifold gasket?? Never delt with this before but it seems like quite a decent leak for just a gasket? I did rule out the hoses and the heater core fitting on the back of the manifold. Could it be possible to dump a lot of coolant from the manifold gasket? I just cant imagine what else this could be. Any thoughts?
My next task will be to get an inspection mirror to see if I can actually isolate the leak. Also I did check that there is no coolant in the oil or oil in the coolant.
Thanks folks!
Thanks folks!
