Originally Posted By: Sequoiasoon
Originally Posted By: spta97
18" was the smallest rim size for armadas and a 17" won't clear the 2006+ larger rotors.
At this point I def want an AT tire. It seems that the cooper discovery is an LT tire which I want to avoid and the Toyo Open Country at2 is 10 lbs heavier per tire which is a lot (~40 vs ~50 lbs).
The terra grappler seems to have diminishing grip as it wears.
Any others to add to the search?
I was looking at Tirerack where they listed 17" as a recommended option. I'm sure you've checked other forums to verify. My friends Titan had 17" on it so figured it was the same. Doesn't Tirerack or some others have a fitment guarantee for you to verify on your vehicle?
Otherwise Nokian Ratiiva AT in the stock 18". Nokian LT2 in 275-65-18 (a little smaller diameter. LTX Winter in 275-65-18
Find some cheap ebay 20" and go
Hakkapelitta 7 SUV
The Rotiiva is an LT tire which I would like to avoid. I called Nokian yeaterday an they sai it would be a much rougher ride. When you ask a Titan guy, they don't seem to have an issue with LT tires but that may be because it is a pickup. In either case, they are not recommended it an SUV like mine.
Nokian had a p metric in my size, Vatiiva I think, that has been disontinued and there is not much info on their site.
The Michelin winter x reviews have not been great on the sites I looked.
17"s won't work due to my larger rotors and calipers and I don't want to buy more wheels so ill stick with the 18"s I have.
I'm not sure why I am finding a lack of p metric tires in this size?
