Originally Posted By: fdcg27
What change interval does Honda recommend for the air filter?
An air filter can be kept in service so long that paying a few more dollars isn't that much of an issue, IMHO.
If it makes you feel better, I paid more than that for an air filter for my old BMW. The one I replaced still looked quite good after at least 35K. If I have to spend a little money every 30-35K, I'm not mad.
Buy a known good brand and leave the off brand stuff on the shelf.
You're just not saving that much over the interval you'll run it.
30K/15K miles or 2/1 year for normal/severe service. The thing about this particular filter was that it was pretty weird looking with perhaps the most unique shape I've ever seen for an OEM air filter.
I would get whatever I could cheap. I remember I'd go to Pep Boys and pick up their Proline equivalent for $12.99. Everything else was more expensive. They were stamped "Made in S. Korea" along with the manufacturing date. I remember passing by a parts store that carried Wix filters, and I asked if they could order it. They said they could with no obligation to buy since they'd just put it in the back. When it arrived I noticed it was identical and probably just a standard filter where Wix had them print their name and part number on it. You know - where the name and part number are printed on the side in crude-looking dot matrix.
This is what it looks like:
http://www.autohausaz.com/acura-auto-parts/acura-air_filter-replacement.html
K&N has a drop in version, but I'm not sure if I'd get it. This one may also be the most difficult to clean and reoil. It's got a huge surface area in a long cylinder. Back then I was wondering if K&N was going to get around to it. It wasn't because I thought it would provide better performance (the stock filter has very little restriction) but that the disposable replacement filters all came with that expensive molded piece and it seemed a waste to toss it every time.
http://www.amazon.com/E-2427-High-Performance-Replacement-Filter/dp/B00062ZXMW
