0W-40 for 223k mile 95 Mercedes E320?
by gregoron
05/31/16 06:22 AM
I hate surprises
by Excel
05/31/16 06:10 AM
Wix coolant filter change and cut open
by A310
05/31/16 03:45 AM
O2 Sensor Voltage
by Falcon_LS
05/31/16 01:36 AM
Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
57 registered (ABomb369, 2015_PSD, aquariuscsm, Astro14, AirgunSavant, AIRJAC3, 4 invisible), 954 Guests and 118 Spiders online.
58031 Members
66 Forums
249620 Topics
Page 1 of 3 1 2 3 >
#3166355 - 10/24/13 02:40 PM Oil recommendation for a 1991 Lexus LS400?
Finn Offline
Loc: Finland
Greetings and salutations.
I'm supposed to pick up the Lexus this weekend and in order to get to the stores on Saturday to pick the oil I'm facing the old dilemma ie. what oil to use.
The car has 120k miles on the clock and has full service history. At this point I do not unfortunately have a slightest idea of what oil has been used but I just wish to treat her well and keep her for a long time.
My use will be mix of cruising in town, commuting and touring perhaps 10k miles per year - my daily driver is the Corolla in signature.
As I have mentioned earlier the 5W-30 is somewhat odd viscosity over here and the availability is limited and sometimes quite expensive, such as Castrol Edge.
This is what the manual says:
These are the 5W-30 oils that seem to be easy to get locally:
Valvoline MaxLife 5W-30: WSS-M2C913-A WSS-M2C913-B WSS-M2C913-C, API SJ, ACEA A1-02/A5-02/B1-02
Ford Formula F 5W-30: WSS-M2C913-B, WSS-M2C913-C, API SL, ILSAC GF-3, ACEA A1/B1
GM Longlife: ACEA A3/B4 ja C3, API SM/CF, GM-LL-A-025, GM-LL-B-025, BMW LL-04, MB 229.51
Mobil Super 3000 X1 5W-30: ACEA A5/B5, API SL, Ford WSS-M2C913-C, Ford WSS-M2C913-B, Ford WSS-M2C913-A
Then there's of course Mobil 1 0W-40 and Shell Helix Ultra 5W-40 and other oils as well.
Of these 5W-30 oils above what would you recommend or does it matter ie. would each and every one suit the 1UZ-FE just fine?
1991 Lexus LS400 | 2000 Audi TT quattro 225 hp | 1978 Corvette 427" | 1986 Corvette 383" | 2003 FLHR | 1984 GSX750EF
#3166365 - 10/24/13 02:48 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
2012AccentSE Offline
Loc: TX
I would get an oil that has a high cleaning ability for the first few changes to flush any old [censored] out. Then switch to an oil of my choice.
2008 F150 KR 5.4L
Oil-?
Filter-?
#3166366 - 10/24/13 02:52 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
dareo Offline
Loc: utah
That engine will be the last thing to ever wear out on that car. Max life would be great, but i think that engine will run forever on just about anything.
2016 Golf Wagon 5MT, 2014 Accord Sport 6MT, 1998 Toyota T100 5MT
#3166372 - 10/24/13 02:56 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
Finn Offline
Loc: Finland
The cost is not the essential factor here but Ford and GM oils - and especially the GM oil - are very, very affordable. Shell Helix Ultra 5W-40 about the same as Ford oil pricewise.
#3166379 - 10/24/13 03:03 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
dareo Offline
Loc: utah
Well if you can get the GM Dexos 2 oil cheaply i'd do that, can't go wrong there.
#3166384 - 10/24/13 03:07 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
hypervish Offline
Loc: new jersey
1UZ-FE is a legendary engine, it'll run butter smooth on whatever oil you use!
2000 Lexus RX300 AWD 234k miles
QS Ultimate Durability 5W-30
Tranny - Castrol Transmax IMV / T-IV
Transfer Case and Rear LSD - Royal Purple 75w-90
#3166386 - 10/24/13 03:07 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
Boss302fan Offline
Loc: Oconomowoc Wi
PP or even plain jane PYB would be good choices.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#3166396 - 10/24/13 03:12 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Boss302fan]
Finn Offline
Loc: Finland
Pennzoil products are not easy to get here but Shell products are on just about every market shelf.
#3166416 - 10/24/13 03:25 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
RISUPERCREWMAN Offline
Loc: RHODE ISLAND
Yeah all that engine needs is an occasional timing belt. That is its only achilles heel. Its an interfearence engine so be careful!
2014 Ram 2500 HD 5.7 Hemi 4x4 7K miles
8'Boss SuperDuty Plow
2015 Harley Davidson Ultra Limited 1600 miles
2009 Toyota V6 XLE Camry 50K miles
#3166421 - 10/24/13 03:30 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
CELICA_XX Offline
Loc: Oklahoma
I have this same car... M1 5W-30 until just recently, and now switched to M1 5W-30 HM
Fantastic car by the way.
15 Toyota Prius - M1 EP 0w20
02 Toyota ECHO - PU 5w30 / KREEN experiment
97 Lexus LX450 - M1 0w40
93 Lexus LS400 - Valvoline MaxLife Full Syn 5w30
#3166428 - 10/24/13 03:37 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
Finn Offline
Loc: Finland
Thanks guys, much appreciate your comments.
Any idea if the GM oil is an OK product?
#3166447 - 10/24/13 04:02 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
tinmanSC Offline
Loc: Oswego, IL
I'd keep is simple and go with Valvoline. People all over the world use MaxLife, works great. But I'm bias.
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
#3166454 - 10/24/13 04:16 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
y_p_w Offline
Loc: SF Bay Area
Here's a thread on that very same oil:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2571182
One of the posts says that GM's suppliers are Wolf Oils from Belgium or Total.
Here in the US I think we have a lot of choices because there's a fairly healthy do-it-yourself market. I was told that in European countries, most servicing of vehicles was required to be performed by licensed mechanics.
#3166455 - 10/24/13 04:16 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
bigt61 Offline
Loc: Virginia
I think the GM Dexos2 would work fine. Use what is easy, cheap and available. Stick with 5W-30.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2487870
92 Suburban 2500 7.4L 58k M1_5w30 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 29k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#3166540 - 10/24/13 05:42 PM Re: Oil recommendation for a 1991 Lexus LS400? [Re: Finn]
fdcg27 Offline
Loc: OH
What would be least expensive?
I'd say that the GM Dexos 2 oil would be a good choice. It meets A3/B4, so it would work well, although it would be a higher HTHS oil than what Toyota originally recommended.
Certainly won't hurt the engine, but probably thicker than needed.
Maxlife might be a better choice. API SJ is a more recent spec than existed when this car was new, so there should be no problems with that. Maxlife has worked well for me in a few applications.
I don't think that it'll hold up for 10K miles, though, while the GM Dexos 2 oil probably will.
You have a great engine in a great car. I doubt that any S-class or 7 series of the same vintage would hold up to time and miles any better if as well.
What an unplesant surprise this car must have been to DB and BMW when it was introduced.
People from both makers tried to trash-talk this upmarket Toyota, but it became solidly popular among high-end buyers, at least here in the US.
It may not have been autobahn bred, but it still runs like a fast and comfortable train.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
Page 1 of 3 1 2 3 >
