Originally Posted By: Richtrashman
PHISHIN---so I read all 9 of your pages and looked at the pics, what do you think your final answer would be regarding the use of restore? as far as using it ($) every oil change it doesn't bother me much, if I cut down on oil consumption the cost balances out.do you think I should change the filter after 500 or so? also do you think that the combination and the volume of several additives could have caused all the goo in your filters? maybe the particulates were from normal engine breakdown (yours obviously had some!)that was stuck in the sludge of the engine you said was there? not doubting your findings by any means just trying a different p.o.v. thanks in advance
main question would you use it again?
Yes, I would use again. In fact, RESTORE is in the oil right now.
I thinking changing the oil filter after 500 miles isn't a bad idea. Is it needed? I don't think so. Heck, why don't you add RESTORE, and run it from 500 or go 3000 miles, and replace the filter? Cut your old one open and show us the results. Just don't cut the filter open with a Dremel like I did. It can contaminate your results.
This spring, I'll send my oil filter to someone on here with a filter cutter and post pics with another run of RESTORE.
Yes, I'd run RESTORE again. Yes, it's in my truck now. For me, since I burn a quart of oil every 500-1000 miles, and since I won't go over 3k miles with any filter, I don't change the oil. I just keep adding.
Originally Posted By: Miller88
If little is good, more is better.
When I started my "RESTORE experiment", I added two cans of the 6-cylinder cans. Since then, I've topped my truck off with 9-10 quarts of oil, and I added another 6-cylinder can. I've changed out the filter twice.
