Originally Posted By: kschachn
If the owner's manual says CHF 11S and/or the cap, then I wouldn't use anything else IMHO. I can't believe someone on Bimmerforums would suggest using Dex III unless the manual allows it. Reading it on a forum (even this one) isn't always good advice.
Why are you working so hard to use something else? You're looking at Amsoil and Prestone AS268, why not just get some CHF 11S? It's really not that hard and I'm sure there's someplace in St. Louis that sells it.
You didn't help him out by putting Dex III in his car, did you?
I have not suggested anything to him other than follow the owners manual.
After downloading the owners manual from BMW, they make no recommendation on the type of fluid used in the power steering.
I guess that BMW does not require power steering fluid maintenance.
Over at bimmerforums there are quite a few threads that state if the caps says ATF, use Dex III/VI, and if CHF-11, you need Pentosin.
What I did find that was interesting was that BMW states plainly in their manual that the automatic transmission fluid, manual transmission fluid, and differential fluid are all lifetime with no changes needed.
