http://www.penriteoil.com.au/products.php?id_categ=1&id_brand=2&id_products=484
At last we are getting ultra low viscosity oils in Down Under.
Ranchu said:What's the point?
From Mobil US web.............. Ask Mobil ........ Ask Your Stickiest Question. . . \
Question:
Is 0W-20 Motor Oil Suitable for Use in Hot Climates
Okay, I am having trouble believing that 0W-20 oil is thick enough for the Florida heat (in summer). .......I do believe 5W-30 is better suited to the Florida climate, especially when you consider the fact that I tow a boat at least once a week.
-- Gary Gilmore, Panama, FL
Answer:
Mobil 1 0W-20 is certainly robust enough to handle the climate in Florida, but considering there is additional towing involved, Mobil 1 5W-30 can provide the extra viscosity you may need when towing.
"Or if you do some spirited driving without towing a 5w30 grade may be better in hot climates to provide the additional protection, which probably applies to most us in OZ."
