Been a while since i hsve posted but have been popping in and out!
Not sure if this engine is fitted to any vehicles in NA but the engine itself is a PSA Group lump, also fitted to the Discovery 4, Range Rover and Range Rover Sport, Jaguar XF and most if not all Peugeot and Citreon vehicles with the 3.0d option, don't know if there are others.
Basically the vehicle was registered at the end of Nov 2011 and has just under 90k on the clock!
Was owned by a Chauffeur and that is the reason I have bought it to continue this usage.
Car has full Jaguar History and was last serviced at around 75k back in June/July, all done with the same main dealer.
The standard service interval for this vehicle is 16k miles of 1 year.
My thinking is to continue with main dealer servicing and perform an interim oil change.
Thr oil filter is an insert i believe and though info is scarce i was thinking of using Mobil Super 3000 X1 FE as it has the required low saps and i believe it needs a fuel economy oil.
Any comments, as usual, welcomed.
Want to run this for four years and up to around 300k then retire it.
