Originally Posted By: ZeeOSix
Originally Posted By: 440Magnum
All of those are great, and the Fram is the best bang for the buck. Fram doesn't get top slot because of its plastic bypass valve poppet- not really a problem IMO, but just not the best possible design. Puro has a thin can- again not expected to be a problem, but noted.
The bypass valve in the Fram is not "plastic", it's high temperature nylon. I see nothing wrong with Fram's bypass valve design, and they do major life testing on the design.
I think I said that ;-)
All else being equal, I'd pick the metal valve. But a) the plastic one should be just fine, and b) the Fram is a good bit cheaper than the RP and Amsoil options and has almost identical filtration performance.
All the ones I named are within a gnat's hiney of each other, only minor details are different. If you throw away price and go for every detail being several sigma overbuilt, then buy the RP or Amsoil. For any other consideration, buy the Puro Synth or Ultra.
