Need Fuel Pump Assembly for Camry
by Nick1994
06/25/16 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
06/25/16 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
06/25/16 10:00 PM
Fram TG 7317 6k miles
by bbhero
06/25/16 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
06/25/16 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
06/25/16 04:47 PM
Where do pets go?
by Whitewolf
06/25/16 04:47 PM
Help reading Bosch 3330 date code
by beavis87
06/25/16 04:11 PM
Castrol magnatec
by ChadW
06/25/16 04:07 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
63 registered (2015_PSD, 67lemans, abycat, austinlunsford, AntsinmyEyes, 7 invisible), 1288 Guests and 8 Spiders online.
58272 Members
66 Forums
250817 Topics
Page 2 of 3 < 1 2 3 >
#3159456 - 10/17/13 10:42 PM Re: BG MOA at every oil change - should I worry? [Re: zeuloa]
Lapithes Offline
Loc: United States
Most likely BG hires a third party agency to handle their "Lifetime BG Protection Plan" claims, which specializes in finding any way possible to deny a claim.
Edited by Lapithes (10/17/13 10:47 PM)
#3159591 - 10/18/13 05:46 AM Re: BG MOA at every oil change - should I worry? [Re: Lapithes]
lubedude13 Offline
Loc: North Carolina
Don't downgrade BG unless you've dealt with their warranty. We have and they do honor it
2010 Toyota Camry:
Amsoil Signature Series 0W20
Amsoil Signature Series Trans Fluid
Amsoil ATF Power Steering Fluid
#3159601 - 10/18/13 06:38 AM Re: BG MOA at every oil change - should I worry? [Re: lubedude13]
Lapithes Offline
Loc: United States
I never downgraded BG. I just stated something which is most likely true. If it bothers you, don't read my posts. All you have to do is click on my profile name, and you'll see the ignore option.
Edited by Lapithes (10/18/13 06:46 AM)
#3159629 - 10/18/13 07:33 AM Re: BG MOA at every oil change - should I worry? [Re: MolaKule]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Originally Posted By: MolaKule
Have the dealer show you where the OEM requires the MOA or any additive for that matter.
Ford and Nissan/Infiniti in this city push the stuff, too. Of course, the manual prohibits additives, Infiniti Canada uses Mobil products as service fill (and XOM doesn't want additives either), yet they do it.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3159636 - 10/18/13 07:37 AM Re: BG MOA at every oil change - should I worry? [Re: Garak]
Lapithes Offline
Loc: United States
Kind of reminds me of how Jiffy Lube tries to upsell washer fluid.
Edited by Lapithes (10/18/13 07:38 AM)
#3159673 - 10/18/13 08:13 AM Re: BG MOA at every oil change - should I worry? [Re: zeuloa]
Lapithes Offline
Loc: United States
BG MOA may compliment an oil that has a lousy/weak additive package, but I just don't see the point in using it with an oil that already has an excellent and advanced add pack. Why salt your eggs twice (yes, I know that some of us really like our sodium)? Now, if your engine has sludge or varnish buildup, maybe BG MOA would help clean some of it out, but it's not marketed as a cleaner. It's marketed as a wondrous marvel that lets your engine run without oil, and protects your bearings by means of a trade secret that the oil companies can't seem to reverse engineer. Imagine a mid-sized company which sold a technology to turn a regular tire into a run-flat tire, but Goodyear couldn't figure the technology out. If BG or any other additive manufacturer wants to convince me that there is actual third-party data/proof behind their product, I will get busy reading.
Edited by Lapithes (10/18/13 08:26 AM)
#3160189 - 10/18/13 06:31 PM Re: BG MOA at every oil change - should I worry? [Re: zeuloa]
steve20 Offline
Loc: Morris County NJ
thanks for the reference to VOA--if you cleaned up the impurities and took the moly out of BG MOA, it would be very similar to the stuff in the pink bottle
427 Chevy Powered
#3160197 - 10/18/13 06:47 PM Re: BG MOA at every oil change - should I worry? [Re: Lapithes]
lubedude13 Offline
Loc: North Carolina
Private message me and I can send you email links of bg studies
2010 Toyota Camry:
#3164975 - 10/23/13 01:28 PM Re: BG MOA at every oil change - should I worry? [Re: lubedude13]
zeuloa Offline
Loc: Nicaragua
Thanks for the studies. They seem a bit vague, and they don't really tip the scale for me. I still don't think MOA can do anything that a good oil with API SN won't do.
#3164976 - 10/23/13 01:28 PM Re: BG MOA at every oil change - should I worry? [Re: steve20]
zeuloa Offline
Loc: Nicaragua
What is the pink bottle?
#3165002 - 10/23/13 01:41 PM Re: BG MOA at every oil change - should I worry? [Re: zeuloa]
Boss302fan Offline
Loc: Oconomowoc Wi
I would use it for a one time OCI with PYB to help as a cleaner... BG products are very good and this looks like it would help clean up an engine.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#3165388 - 10/23/13 06:44 PM Re: BG MOA at every oil change - should I worry? [Re: Boss302fan]
zeuloa Offline
Loc: Nicaragua
If that's the case than my engine must be squeaky clean as it's been used by dealer at all but 1 oil change. However, I dont plan to use it any longer.
#3167811 - 10/25/13 08:06 PM Re: BG MOA at every oil change - should I worry? [Re: zeuloa]
vssjim Offline
Loc: McLean, Va.
To be 100 % on the up and up about MOA every car I have worked on it that used it looked dirty inside, we don't sell BG at work but have some people that bring it with them. BG 44K doesn't show me much either we use Techron because it works better in our inspections with cars that have used both and Techron is a better value cost wise. I always worry about companies that bribe users or salesmen.
#3167937 - 10/25/13 11:14 PM Re: BG MOA at every oil change - should I worry? [Re: vssjim]
Lapithes Offline
Loc: United States
Wow...that is interesting. I wonder if that's just a coincidence, because if it isn't, it totally goes against what BG MOA is supposed to do.
Edited by Lapithes (10/25/13 11:21 PM)
#3172271 - 10/30/13 06:57 AM Re: BG MOA at every oil change - should I worry? [Re: lubedude13]
itguy08 Offline
Loc: Somewhere
If it's anything like their [censored] "bgfueltest.com" website/car experiment you could drive a tractor trailer through the holes in their "studies".
There are lots wrong with their "study" but the huge one is when they do the dyno runs (you can see on Youtube) they dyno an AWD car on a 2WD dyno with the driveshaft disconnected and the AWD MIL light on! And then never post the dyno runs.
