Originally Posted By: css9450
Originally Posted By: doitmyself
Sometimes it helps to rub white paint into the timing marks (only) so they show up better.
I don't know if its been mentioned, and maybe its not applicable to the 4.3 engine, but sometimes there is more than one groove on the harmonic balancer. The widest groove should be TDC for the #1 cylinder. That's the one that needs some white paint in it. Bump the engine over a little at a time with the starter until the wide groove comes up where you can reach it and dab some white paint in there. I'm sure White Out or Liquid Paper would work fine.
Go back a dozen pages or so and find what your timing is supposed to be. The smaller V6s (ie, 2.8) are 10 degrees before TDC (10 degrees before the zero mark). If I remember right, someone posted on here that the 4.3 is supposed to be timed to zero degrees. That's with the EST connector under the dash unplugged. Put a dab of white paint at the zero mark on the timing tab. Then, with the timing light connected to the battery and the sensor clipped to the #1 plug wire, start the engine and you'll see it flashing. Aim the timing light down towards the timing tab. Your spots of white paint will show up like neon. The goal is to rotate the distributor until the mark on the harmonic balancer (which due to the effect of the strobe light now appears to be stationary) aligns exactly with the mark on the timing tab. Tighten the bolt at the bottom of the distributor. Check the timing once more to be sure you didn't bump it, and you're done.
TIMED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I think I got it to within about 1 degree. The timing light was cheap, fubar, and not flashing very well off of Cyl. #1.
I did it in the dark, saw a mark, basically had to turn distributor all the way one way... Very carefully tightened nut down a lot, and did so on a HOT engine. Slight surge at idle is basically gone now (maybe a teeny bit due to continued vacuum leak, small, and I know where it comes from) but
OMG THE ENGINE IS TIMED AND I FEEL ABOUT 90% OF THE POWER BACK.
I spun the tires coming off a light with it.
And the SES still comes on and goes off, just not as much........ Not in "Field Service" mode with ALDL...
And no pics: 1. No camera/phone. 2. I needed to concentrate. 3. That timing light was better than the first, useless one, but still cheap and intermittent. Had to really fight with it, and even then it didnt flash too well. It is amazing I got it done with such a cheap light.
Videos will come "soon" but WOW what a difference. (Blockbuster Video! Wow. <-- Remember that commercial?)
