dnewton3
Staff member
I realize what GM calls the G-80, but that does not make it a real "locker" they way I was raised to think of them to functionally be. The G-80 is a glorified, part-time LSD, period. It most certainly has clutches, and it will not function well without FM. Actually, they don't make it; they buy it from Eaton, and then AAM puts it in for GM, but that's semantics ...
here is a youtube video of the G-80
http://www.youtube.com/watch?v=tTGZOJQQBeE
you can see in the video the clutch packs on both sides, and they speak of the ramping action against the clutches. And I quote " ... the active friction discs" .....
They speak of the friction disc packs several times. This is not a true "locker" like an Air or E-locker, folks. This is an LSD that uses a governed application mechanism to operate part time. Unlike a traditional LSD where the clutch pack is always engaged, the G-80 only actuates full force to the "friction discs" when the axial loads ramp out to put pressure on the disc packs on each side. When not activated, the ramping is relaxed and the clutches are only partially in play. That is why FM is needed; if it were not there, the clutches would grab and create chatter and/or nuisance locking, which is a common complain when folks do not use a fluid with FM in these units. Make no mistake, there are clutches in there, and they need FM.
As for the fluid, I would like to see the specific wording; I doubt it "requires" synthetics. I'm sure it "recommends" such, but rarely do they require it.
Most often, they state something like "recommend the use of a fluid that meets GM spec 9986115, part number ...." That "spec" is merely for a pre-mixed 75w-90 syn using FM, and the part number is the call out for the OTC convenient quart. Like the Amsoil link states, GM actually uses different specs for the factory fill, because they purchase separate lube and FM, and then mix it themselves at the factory. Whereas the OTC bottle needed to have a separate spec so that the blend knows exactly what to put into the bottle. In my 2006 GM truck manual, nowhere does it "require" the use of synthetic; it is only "recommended".
Ford manuals are similar; they push their products. But when it comes to engine oil, my Mercury manual specifically states that the use of synthetics is "not required". But that does not stop them from "recommending" their own Motorcraft synthetic by name.
