Yesterday I changed the passenger side front wheel bearing hub on my daughters car. The car is a 1997 Chevy Cavalier with 190,000 miles. The bearing was noisy and loose.
The sealed unit I replaced it with was a Raybestos 713017K Professional Grade Wheel Hub and Bearing Assembly.
If you click the link, you will see this unit included a seal and O-ring. There was no place to use these on this car. But now I'm concerned that I did something wrong and the parts were needed somewhere. Maybe they would be needed on another vehicle that also used that bearing? I've changed several front wheel drive bearing hubs and never encountered one that had a seal and O-ring in the box.
So, what is the seal and O-ring for?
