Ford Powershift Gearbox Class Action (Oz)
by hpb
05/04/16 03:50 AM
Central Mississippi automotive goods
by mjoekingz28
05/04/16 02:11 AM
Free: 5 Quart jug Peak 5W-30
by Indyvwhonda
05/04/16 01:01 AM
Subaru Oil Burning Class Action
by Bandito440
05/03/16 11:43 PM
'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
05/03/16 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
05/03/16 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
05/03/16 10:38 PM
Briggs and stratton flathead?
by pdxglocker9mm
05/03/16 10:27 PM
Charcoal
by dlundblad
05/03/16 09:43 PM
2013 Dodge Dart: replace AF on miles or time?
by vitez
05/03/16 09:20 PM
Rotella T5 10w30 or QSUD 5w30
by GumbyJarvis
05/03/16 09:04 PM
People running thru red lights. You ever follow th
by motor_oil_madman
05/03/16 08:30 PM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
36 registered (bandz7, Astro_Guy, alcyon, Deltona_Dave, car51, 7 invisible), 550 Guests and 316 Spiders online.
57790 Members
66 Forums
248438 Topics
Page 2 of 3 < 1 2 3 >
#3149703 - 10/08/13 09:02 PM Re: Whos using 15W40? [Re: GSCJR]
sirgerman Offline
Loc: ca
Originally Posted By: GSCJR
Running it in my 1996 SL2 that specs 5w-30
me too saturn sl2 2002 with 170 000 miles , that the only oil that help with consumption
#3150761 - 10/09/13 10:07 PM Re: Whos using 15W40? [Re: Realtech214]
simple_gifts Offline
Loc: Middlesex County CT
Tried it in my !Echo! last fall; low temp (20F) startup valve clatter was unbearable to the point where I drained it.
Great summer oil however.
Edited by simple_gifts (10/09/13 10:08 PM)
2003 Echo >390K miles; Showing its age.
2006 B2300;101K;ALM
Please conserve paper; it is not like it grows on trees.
#3151082 - 10/10/13 10:01 AM Re: Whos using 15W40? [Re: Realtech214]
hattaresguy Offline
Loc: CT
I use it in the Cummins in my boat, that's about it.
Never noticed a difference between the big brands of 15w40 ie Rotella, Delvac, or Delo, so I buy whatever is on sale.
#3151549 - 10/10/13 05:40 PM Re: Whos using 15W40? [Re: Realtech214]
dennishiip Offline
Loc: Ca
I use Delo 15W-40 in my '92 Mercedes 190E
#3153967 - 10/13/13 05:27 AM Re: Whos using 15W40? [Re: Realtech214]
95busa Offline
Loc: Tennessee
I ran a cycle in my f150. It seemed fine, but I am not sure it would be the best call for winter, so I switched to qs defy 10w30.
2005 Ford F250 Super Duty 4x4
2009 Dodge Grand Caravan
2014 Kia Forte KOUP- totaled by a drunk driver
#3154314 - 10/13/13 12:45 PM Re: Whos using 15W40? [Re: Realtech214]
dixon700 Offline
Loc: pa
I only run delvac 1300 15w-40 in my 5.9l cummins in my truck. I'm thinking of switching over to the delves oil in my Kubota that calls for 10w-30. My car even with the 203k mi it still doesn't really use enough oil for me to thicken it up.
Edited by dixon700 (10/13/13 12:47 PM)
04.5ram CTD lots of parts delvac15w-40 just delvac next time Donaldson elf7349 02 elantra gt castrol edge10w-30 oem filter
#3175392 - 11/01/13 07:31 PM Re: Whos using 15W40? [Re: Realtech214]
VWguy Offline
Loc: Los Angeles, Ca
I'm using Chevron Delo 15w-40 in my '71 VW Bus (7qt capacity with full flow, by-pass filters, and sump). The oil I got is the pre LE version. I have used the 15w-40 oils in many air-cooled VW's. A bit off topic but stumbled onto the Shell Rotella T 10w-30 oil here in Los Angeles' Pep Boys and am using it in a new friends stock '74 Karman Ghia 'vert that has used Pennzoil yellow bottle (PS: thanks Shell). Bill
#3178297 - 11/04/13 02:23 PM Re: Whos using 15W40? [Re: Realtech214]
VWguy Offline
I also have a "beater" '74 bug which has an engine which has been documented, on previous owners repair orders, to have overheated and I use the HD oil. I am using 15w-40 in the cooler months and a straight 40wt during our So Calif summer.
I have a couple of customer/friends that own nice older VW's and I have used the 15w-40 oil in those also.
PS: These dual-rated oils are so nice to have available for the older flat tappet air-cooled cars that I own and service. Bill
Edited by VWguy (11/04/13 02:25 PM)
#3178909 - 11/05/13 07:09 AM Re: Whos using 15W40? [Re: Realtech214]
951Indy Offline
Loc: Indy
Premium Blue 15-40 is used in my 3.8 GM as a make-up oil, when its the easiest thing to grab from my leftovers.
#3179604 - 11/05/13 07:24 PM Re: Whos using 15W40? [Re: Realtech214]
artificialist Offline
Loc: Florida
What does a Ford 460 specify in the owner's manual? Gasoline or diesel, U-Haul calls for 15w40 oil in their trucks.
2010 Lancer Ralliart Sportback
#3179693 - 11/05/13 08:32 PM Re: Whos using 15W40? [Re: Realtech214]
bullwinkle Offline
Loc: Cincinnati, OH, USA
A newer 460 would be 5W20, older one likely 5W30-it would use a lot less if it had 15W40 in it (at least an older, worn U-Haul motor).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3179723 - 11/05/13 09:06 PM Re: Whos using 15W40? [Re: bullwinkle]
VWguy Offline
I agree with Bulwinkle's post. I worked for a large gov't fleet here in So Cal and for decades had used the 15w-40 oils in everything, to include the Ford modular engines. Ford did not like this use of the heavy oils but I can say we never had an oil related issue. The last few years we were kinda "encouraged" to use the recycled fleet oils. Bill
#3179954 - 11/06/13 06:50 AM Re: Whos using 15W40? [Re: Realtech214]
toneydoc Offline
Loc: War Eagle
I mix it with some HD 20w50 oil in the Harley and use it straight in my engine in the John Deere lawn tractor. Also goes in the other small engines outside.
1994 Jeep 145k Castrol 0w40
2014 Camry 13k TGMO 0w20
2010 Sebring 39k Penn Plat 5w20
2014 HD Ultra 16k Valv20w50
2012 Toyota Rav4 21k Mobil 1 0w30AFE
#3180619 - 11/06/13 06:47 PM Re: Whos using 15W40? [Re: bullwinkle]
jayg Offline
Loc: Anchorage, AK
In my 460 (Continental) I had, I ran 10w30. Did perfect.
'15 Toyota Prius C TGMO 0w20
'91 Toyota Land Cruiser VWB 5w30
'73 Datsun 240Z 4sp Vintage QS 10w40 from '73 in the sump
#3182131 - 11/08/13 11:31 AM Re: Whos using 15W40? [Re: Realtech214]
1 FMF Offline
Loc: CT
used in my 2002 camaro LS1 since new, 70k miles now, still have 40 psi at hot idle 800 rpm.
used in my 2005 altima during summer to 40k miles till i sold it
used in my boat, 2002 3L merc i/o
being using it in my 2006 sierra with 8.1L motor, has 75k miles now.
used in 2012 outback during summer.
