My 2001 Dodge Ram 2500 4x4 with Cummins I-6 diesel has the 47RE overdrive transmission specifying Chrysler's ATF +4 only. An independent diesel specialist shop drained, flushed and refilled with Dexron III / Mercon plus 20 oz ATP AT-203 synthetic friction modifier, claimed to provide equivalent performance as a highly friction modified ATF.
The manager said Dexron III has better "lubricity" and is preferred based on his long field experience. I must say the shift characteristics were smoother after the change, without the usual torque-converter lockup judder. However, the manager said on a later visit he has to document all future ATF changes for Chrysler 47RE transmissions with ATF +4 for warranty / claim purposes.
My conservative thought is to follow the service manual and not try to reformulate to lubrication specifications with off-the-shelf additives. Any practical advice is welcomed.
