TechnoLoGs
Thread starter
Originally Posted By: Clevy
Ght
The dizzy is mounted on a shaft. At the base of the shaft there will be a clip that has a bolt head affixed. With engine off unhook the vacuum line that is plugged in to dizzy.Start engine.Loosen the bolt head. That will allow you to turn the entire dizzy either clockwise or counterclockwise. Turn the dizzy a smigeon,tighten bolt,turn off engine,hook vacuum line up,test drive.
I don't know which will advance the timing on a 4.3 but that's how it's done on a vacuum advance distributor. If you've got an hei ignition I don't know how to disable the advance to set initial timing.
You are net savvy. I'm sure you can dig up a YouTube vid on how to adjust timing.
OMG! I see a disconnected line there.. a vac line plugs into the dizzy?????
That could be the issue right there, it is clean off...................
Ght
