After running into this site just a few weeks ago, I have given my oil filter more thought than ever before. Reading through the archives on this site has only confused me even more. Anyway, I want some advice on my oil filter choice. I have to change the oil on one of my cars next weekend, so I need to make a decision on a filter.
On my 305 Chev truck, I think I am just going to run an AC/Delco Duraguard PF1218. For the money, it seems to be a good filter, plus it has the addition of the ADBV (I was using a PF35).
Now the confusion comes with my Olds powered cars. I have run either AC/Delco PF58's or Purolator Premium Plus L20123 (PF-58 equivilant) the past. After doing much research, I found that there are two larger sized filters that will work on my Olds V8. One is the PF-24 and the other is the PF10. The PF24 isn't available at my local Wal-mart and cannot be ordered. The PF10 is discontinued by AC/Delco.
But, I can also get Wix and Purolator filters locally. The Wix 51049 is a largest filter that wil fit my car, but it does not have an ADBV. THe Purolator equivilant (L30005) has the ADBV. From what I have read in the archives, flow seems to be just as important as filtration. And it seems that Purolator filters do not flow well. I would likely only use the Premium plus line on my cars, as I don't want to spend more than $10 per filter.
Anyone have any idea what is the best filter to run? I drain the oil on short intervals in these vehicles. The big Purolator L30005 seems good, but I don't want a restrictive filter. Are the Premium Pluses restrictive? Wouldn't the much larger size permit it to flow better? And the Wix has no ADBV, plus they are pricey at $11 CDN. I don't really want to stick with the tiny PF-58 with no ADBV.
Any advice appreciated.
