Originally Posted By: BusyLittleShop
Originally Posted By: SuzukiGoat
Personally, I put only nonfriction modified oil into shared sumps.
Honda/Yamaha parts and service certified tech.
Friction modifiers additives are only about 10% of the oil product and
help the base oil do things that it otherwise could not... Additives
fall into several basic categories but Moly is the most often used
friction modifier because it has such a high melting temperature
(4730¯ F versus 2795¯ F for iron), it works great as a
high-temperature, high-pressure antiwear agent. Some still believe
that because moly is so slick its the cause of their clutch
slippage... but note that 6 of the 19 motorcycle oils used moly
including the HP4 market by Honda for any of their motorcycles
Technically speaking a wet clutch in good working order is not about
to slip no matter what oil ans additives the owner selects... what is
confusing the issue is the fact that all motorcycle wet clutches will
reach a point in their life and start to slip... have you notice that
no one complains about clutch slip when new... its about the 27K to
57K range that contaminants build up to point where the clutch may
begin to loose its grip most noted during a WFO (Wide Fooking
Open)throttle burst... in error the oil could be blamed but
technically speaking its really the condition of the clutch plates...
So the notion that we should only use nonfriction modified oils is on
shaky ground... fact is I've been using 10/30 0/30 Energy Conserving
Mobil 1 with 98 ppm Moly since 98 in Mr.RC45 with no clutch slipping
due to oil being certified 10% freer flowing than non EC oil... and as
you should know we're talking about Mr.Honda's homologated racer with a
tall first gear good for 90mph that's known to incinerate clutch
plates...
A dumb guy with a Lathe and Mill...
I can fully agree the moly or any friction modifiers causing clutch slip is over blown. I've never skipped a clutch even racing until it was worn thank the stack height was off. I've used many different oils too which would have worried some. Probably too much worrying or over thinking goes into this idea.
