Originally Posted By: momo
Hi all,
Does anyone have any experience using a decent cold air intake filter for 3MZ-FE?
If you follow your factory intake tract forward of the air cleaner, I think you may find that your engine already has a cold-air intake; i. e.: the air is drawn from ahead of the radiator support, outside the engine bay.
Toyota uses Mass Airflow Sensors (MAF). Since aftermarket cold-air intakes tend to have filters that are not as efficient as the OE system, lots more dirt is allowed in, which eventually causes problems with the MAF. This leads to the Check Engine light illuminating, plus driveability problems.
