With costs of fuel on the rise I can only wonder of ways to increase fuel efficiency. This led me to ask how long does a typical OEM oxygen sensor last? How do you know it is not working per spec? I wondered about this and then hit the internet to do some research on the subject and the interesting thing is I did not find a whole lot except that people automatically assume they need a new O2 sensor when their car fails emissions or the check engine light comes on and when they do replace it, they still have the original problem. I read that some of the symptoms of a bad sensor is sluggish performance, poor fuel mileage, and failed emissions. However, all of the places I read this was from sites that either sold O2 sensors or has affiliation with a company that does.
For me, I own a vehicle with 135,000 miles on the odometer and still have the original Heated Oxygen Sensor (OEM by Denso). No check engine light has ever come on throwing a code for the O2 sensor circuit nor have I ever failed emissions (However my NOx was close to the limit last time I ran emissions). So what I am left to ponder is whether or not I should go ahead and replace something I do not know will show any improvement or benefit and end up costing me $70 to learn a lesson. Everyone I talk to tells me I should replace it every 50-70k miles, but my manual does not indicate anything about it even at 120,000 miles and I am led to believe that modern O2 sensors are like today’s engine oil in that they last longer and perform better than their older counterpart. Others tell me that an O2 sensor react slower over time and could operate outside of spec and still not throw a code.
Does anyone have any knowledge on this subject? Has anyone who replaced theirs noticed any improvement when replacement was not necessary by means of check engine light or high HC or CO levels? I figure if I can save just 1 mpg I could buy a house since I am paying close to $2.50 per gallon. (Yeah I know, I should not complain until I am forced to buy gas in Europe).
