I recently posted an add on Craigslist looking for a used gas powered edger for $30 or less. Guy replied that he had one for $30 bucks and it ran for a few minutes and then stopped, might need carb work. I took a gamble and drove across town to pick it up. Guy started it up with one pull, it ran fine for about 30 seconds, and then he shut it off. It appeared to be a good candidate for what I needed, so I handed over the $30 bucks and loaded it in my truck.
I took it home and inspected it to find out what I just bought. Appears to be a Tru-Cut Estate brand edger with a Honda GC135 engine. Never heard of the brand, so I googled it and found this to be a commercial unit sold at dealers for $550-$700 when new!!!
Feeling pretty good about the deal now. Began my routine maintenance inspection to see what it needed. NGK spark plug was loose (!) about 1/2 turn. I checked the gap and found it to be at .37 when factory spec is .28-.31. The spark plug was in good condition so I regapped it to .30, cleaned it, and reinstalled it.
Air filter was clean and appeared to have been replaced in the last year.
Plastic oil dipstick was STUCK in the block. I had to use a wrench to get it off. Wiped off the oil, reinserted it, pulled it out and found there to be absolutely no oil on the dipstick. Not a good sign. I looked down into the oil hole and saw the nastiest, thinnest, aluminum filled oil I have ever seen. Gross. Pulled the drain plug and only about 4 ounces (maybe) of silver metal paste oil came out. Maybe there is a low oil sensor on this motor that keeps shutting it off and that is why the genius couldn't keep this thing running for more than a few minutes? Or worse, he ran it until it seized? It seemed to run good and strong for the 30 seconds I heard it run. I refilled the crankcase with SAE30 oil. I will do a super short run on this oil and then change it again to try and get out more of that metal paste.
Checked the gas in the plastic fuel tank and found it to be off color, possibly filled with premix oil and gas mix. I also found a large amount of rust particles and sediment floating around in the tank. I took the tank off and flushed out the garbage that was in it, cleaned the fuel screen, and reinstalled the tank. Filled the tank back up with fresh clean gas with stabil.
There are several zerk fittings on the edger so those got a couple pumps of grease. I doubt they have ever been greased based on the total lack of maintenance I’m seeing on this Honda engine.
I just finished up and it is past 3AM, so stay tuned for an update. I run it tomorrow when the sun comes out so as to not anger the neighbors.
I found a picture on the net of the edger.
