Hey guys,
I just finished applying Opti-Coat 2.0 on my daily driver - which is a 2011 Prius. Although my car had been well-maintained with a coat of paint sealant every 6-8 weeks, I decided to upgrade to a permanent paint coating in order to reduce maintenance. The Opti-Coat 2.0 product is designed to be a permanent coating that can only be removed with an aggressive compound - it cannot be chemically removed.
Prior to applying the coating, the paint was thoroughly washed, de-contaminated and given a one-step polish. I would have done a two-step correction on certain areas, but I was trying to preserve as much of the clearcoat as possible. Overall, I attained between 60-80% correction on most panels so I am fairly satisfied with the improvement. The total time spent was about 11 hours.
What was done:
- Wheel faces and barrels were cleaned with Eagle One Aluminum Wheel Cleaner
- Initial car wash was done with Meguiars Gold Class, grit-guard and P&S Wash Mitt
- Nanoskin Auto Scrub Wash Mitt (med-grade) was used to remove the bonded contaminants
- Iron-X Paste was used for the removal of embedded iron deposits
- Polish was done using a Flex 3401XRG and HD Polish. Uber Green, LC Orange and Meguiars Yellow polishing pads were used.
- Final wash was done by soaking the entire car in Optimum Power Clean (diluted 1:1) to remove any polishing oils leftover in order to allow for proper bonding of Opti-Coat 2.0.
- Opti-Coat 2.0 was applied to all painted surfaces
- Menzerna Power Lock was applied to the clear bra
- Tires were dressed with Optimum Opti-Bond
Here are some pictures that were taken with my iPhone. I do not have another camera so I apologize for the lack of detail.
On this particular panel, it came out near-perfect after several passes with HD Polish:
So far, I have only found one high spot from my application of the Opti-Coat 2.0. Hopefully I won't find too many more. Dealing with high spots is the most challenging part of the application process.
I will post some pictures of the water beading once I wash the car in a week or two.
What was done:
