Battery or starter
by Dallas69
08/27/16 07:56 AM
Napa Syn 15w50 to replace BradPenn 20w50 in 454bbc
by FlyNavyP3
08/27/16 07:51 AM
Real Main Seal Leak ? ? ?
by larryinnewyork
08/27/16 07:35 AM
Gov't wants to lower speed limits for trucks
by JetStar
08/27/16 07:11 AM
GM 55560202 longlife cut open - 10782km
by turboseize
08/27/16 04:54 AM
Coolant Question.
by Farmer
08/27/16 04:20 AM
Stocking up for the Eco
by buck91
08/27/16 12:25 AM
Mobil 1 10w40 HM
by SubyRoo
08/27/16 12:16 AM
What type of glue for door panels?
by Nick1994
08/27/16 12:07 AM
Painting rear of chrome bumpers
by buck91
08/26/16 11:09 PM
Walmart Rifle Clearance
by hatt
08/26/16 10:44 PM
Vehicles That Must Idle For Long Periods Of Time
by BlueOvalFitter
08/26/16 10:30 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
77 registered (AirgunSavant, 4WD, A310, 97f150, 3800Series, 2009Edge, 4 invisible), 1293 Guests and 37 Spiders online.
58935 Members
66 Forums
253614 Topics
#3133947 - 09/23/13 10:00 PM Motorcycle oil for a NV5600?
Cummins12valve Offline
Loc: Alberta, Canada
Hello, new to the site. I am curious whether any of the new motorcycle synthetic oils are harmful to brass synchros?
Would the friction modifiers in motorcycle oil help or hinder shift smoothness? Just looking off an off the shelf alternative to the $30 quart Dodge oil. All opinions appreciated, thanks.
1996 Dodge Ram 2500 CCLB, 2wd, 12 valve Cummins, NV5600, 3.54 D80.
1990 Dodge W250 RC, 12 valve Cummins, 47RH, 3.07 D61/D71.
#3133952 - 09/23/13 10:07 PM Re: Motorcycle oil for a NV5600? [Re: Cummins12valve]
dparm Offline
Loc: Chicago, IL
What is that trans spec'd for?
2011 BMW M3 sedan ZCP
#3133958 - 09/23/13 10:19 PM Re: Motorcycle oil for a NV5600? [Re: Cummins12valve]
Mopar's oil is a 5w30ish weight oil according to internet research..But I believe Amsoils MTL is a 70W80, and they say it can be used in place of 5w30, 10w30, and 10w40 in transmissions. MS-9224 is the spec number, Texaco 1874.
Edited by Cummins12valve (09/23/13 10:23 PM)
#3133972 - 09/23/13 10:34 PM Re: Motorcycle oil for a NV5600? [Re: Cummins12valve]
dparm Offline
Loc: Chicago, IL
There's an important distinction to be made here: does the trans say you can actually use motor oil, or does it have to be gear oil? It's true that motor oils and gear oils can have similar viscosities, but the additives are very different.
#3134072 - 09/24/13 06:09 AM Re: Motorcycle oil for a NV5600? [Re: Cummins12valve]
widman Offline
Loc: Bolivia
You should use synchromesh fluid in there. it is thinner that most motorcycle oils and has the right additives for that transmission.
Richard's Car Restorations
#3134130 - 09/24/13 07:30 AM Re: Motorcycle oil for a NV5600? [Re: Cummins12valve]
ddtmoto Offline
Loc: Utah
Is a GL4, GL5 called for in owners manual? use the correct lube...use the good stuff
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
#3134173 - 09/24/13 08:32 AM Re: Motorcycle oil for a NV5600? [Re: Cummins12valve]
Thanks for the replies, I am going to go with the amsoil synchromesh 5w30. I will let y'all know how its working after a few thousand kms.
#3134631 - 09/24/13 02:18 PM Re: Motorcycle oil for a NV5600? [Re: Cummins12valve]
Ken2 Offline
Loc: Washington St.
The motorcycles I'm familiar with do not have synchronizers--they are not sliding mesh transmissions. They are constant mesh transmissions.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
