I'm coming up on 100K soon on my 1.8L Corolla and am thinking of changing out the "lifetime fill" transmission fluid. Currently it is a dark but intense red with a definite tinge of black crud that really shows as black when wiped on a white paper towel, and the red wicks away. Transmission works fine. I'm thinking of doing a few 5K drain/fill cycles and then a full flush and fill.
So my product questions are, are there any experiences/preferences as to new gasket&screen (Toyota, WIX 58324, Hastings TF165, Purolator P1294 etc.), and ATF Fluid- what aftermarket synthetics meet Toyota's spec? (Is there a spec?)
And a procedure question, when in the cycle should I drop the pan and replace the screen and clean the magnets? I was thinking after the drain/fills and before the full flush&fill.
Thanks!
Thanks!
