Recommend CHEST Holster
by Smoky14
54 minutes 18 seconds ago
School decision
by NavyVet88
59 minutes 34 seconds ago
TPMS rebuild kit
by Donald
Today at 10:29 AM
Plastic rivets
by buck91
Today at 09:56 AM
TV-Bluetooth Advice for MIL
by dkryan
Today at 09:51 AM
Pump vs auto loading Shotgun
by FirstNissan
Today at 09:32 AM
PYB & PHM reduced @ Wal Mart
by car51
Today at 09:30 AM
Ugly New Prius #2
by AirgunSavant
Today at 08:32 AM
Getting hurt at work
by ram_man
Today at 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
Today at 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
Today at 12:04 AM
Interesting website for comparing guns
by 901Memphis
Yesterday at 11:45 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
80 registered (Bandito440, AandPDan, Al, 2002 Maxima SE, 4WD, Astro14, 4 invisible), 1779 Guests and 9 Spiders online.
58943 Members
66 Forums
253666 Topics
#3133265 - 09/23/13 10:04 AM Mazda 3 front end loose feeling over bumps
ryan2022 Offline
Loc: Calgary
Hi guys,
My Dad has an 06 Mazda 3 sport.
Its got 50k miles or so, and has a strange issue. Our mechanic says the motor mounts are fine and front end is tight.
Dad drives quickly at times, and says its most noticeable on on ramps hitting small bumps. It skittered across the pavement and feels unsettled.
He isn't pushing it to its limits, just enjoying the car.. I'm wondering if its the shocks, but it seems premature.
Any thoughts from 3 owners?
2016 Mazda CX-3 GS Castrol Edge 0w20
2011 Ford Ranger XL 4 cyl. Quaker State 5w20
#3133268 - 09/23/13 10:07 AM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
Boomer Offline
Loc: Pennsylvania
Tires? Tire pressure?
2013 VW Passat TDI SE, 33,300 miles
2014 VW Jetta TDI SportWagen 18,055 miles
#3133280 - 09/23/13 10:18 AM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
IndyIan Offline
Loc: Ontario, Canada
That does sound like shocks if the front end is tight, maybe very high tire pressure?
Try driving it on broken and patched pavement, if one front tire imitates a basket ball then you know that strut is blown.
07 Focus ZXW, 5spd manual, 151km VWB 5W30
06 CRV, 5 spd auto AWD, 262km M1 EP 5W30
#3133281 - 09/23/13 10:19 AM Re: Mazda 3 front end loose feeling over bumps [Re: Boomer]
SatinSilver Offline
Loc: Ohio
Alignment shop and make sure gas tank is half-way filled up.
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC 822 filter
#3133291 - 09/23/13 10:36 AM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
supton Offline
Loc: NH
Seems early for struts, but "way back when" it seemed to be general consensus that on my vintage Jetta the OEM's were done for around 40k. Most people drove past that point until it failed inspection with completely dead struts--but the cognescenti were convinced that the struts were not up to par at 40k.
Maybe the same here? Struts just not as good as they used to be? Especially after a number of years of "occasional" spirited driving?
2011 Toyota Camry, base, 6spd manual, 119k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 129k, his
#3133307 - 09/23/13 10:48 AM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
nitehawk55 Offline
Loc: Ontario , Canada
I'm thinking struts too unless the mechanic missed something which is possible .
05 Ford Five Hundred AWD 3.0 DOHC V6 CVT tranny
#3133310 - 09/23/13 10:49 AM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
ARCOgraphite Offline
Loc: N.H, U.S.A.
The strut tops (bearings) on my 1991 626 were toast at 30K miles. Three to 4 Bearings all knocked out of the race.
also make sure tire are no more than 2psi over-inflated and the wheel bearings do not have excessive play ( wiggle the tire with each end jacked off the road <or> on a lift). Also grab the rack under the car by the tie rods and see if you can feel if the inner joints (in the rack) have slop. While your under there check the AS bar links and ends any problem which would have been obvious to your mechanic on a quick visual.
Edited by ARCOgraphite (09/23/13 10:52 AM)
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3133331 - 09/23/13 11:02 AM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
GSCJR Offline
Sounds like you need struts.
03 3.0L 1MZ-FE FS 5w-20-ProSelect 21348-222 KM
10 3.5L 2GR-FE CEB 0w-20-ProSelect 27047-140 KM
#3133384 - 09/23/13 12:05 PM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
Quest Offline
Loc: beaver land EH?
methinks struts and sway bar end links.
Typical with the ever-so-compact FWD these days....esp. with struts where over 90% of the mechs out there mis-diagnosed (or simply cannot diagnose defective/weak struts properly).
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3133724 - 09/23/13 06:32 PM Re: Mazda 3 front end loose feeling over bumps [Re: Quest]
ryan2022 Offline
Loc: Calgary
Thanks guys, I appreciate the responses.
I'll start the hunt with Dad.
#3134074 - 09/24/13 06:10 AM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
Char Baby Offline
Loc: Western NY
My daughter's '06 Mazda 3i was doing a similar thing on the highway. When we'd go over broken pavement, the steering wheel was viberating from side-to-side and very sloppy. We ended up installing one lower control arm and both front struts(loaded) and rear shocks too.
Now, it's perfect!
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3134505 - 09/24/13 12:44 PM Re: Mazda 3 front end loose feeling over bumps [Re: ryan2022]
FordTrucks71 Offline
Loc: metro Detroit burbs
Simply struts! 50k mis can certainly end the service life of any cars struts...replace rear shocks to for best performance!
13 Ford Edge 1200mi PP 5w20 M1 filter.
11 Mazda 3s 33k mi PP 0w20 Purolater P1 filter
86 Buick Grand National 44k mi ValvolineVR1 10w30 K&N filter
