Okay, here is an interesting UOA found on a finnish Volkswagen forum. Castrol Edge LL 5W-30 Professional in service for 6300km / 3700 miles.
The vehicle in question suffered from a failed timing chain and the sample was taken while the vehicle was sitting at the dealer's waiting to be repaird. After a huge fight with the dealer, customer won and got a factory repaired engine but only after when the owner complained directly to Volkswagen in Germany.
Comments from the lab:
"ACTION REQUIRED, LOW TBN: Identify and correct the low TBN value of reason. - Possible low TBN value reasons are: 1 poor combustion, excessive bypass, insufficient oil increase, 2 the lower the value of having a TBN of oil caused by the
mixing / contamination, 3 high water content is too low engine temperature and / or prolonged oil change intervals, 4 use fuel with a high sulfur content, 5 low TBN may indicate that the oil is acidification, and that there is very little alkalinity
left, 6 make sure that the product is in the right (engine / transmission). - Take a new sample to make sure that the problem is fixed."
https://www.dropbox.com/s/ypnjb9gbwho2ztp/Sample_Report%5BKA-2%5D.pdf
