Originally Posted By: Schmoe
Exactly what is flat spotting? I know the point where the tire hits the concrete will be flatter than the rest of the tire. But, once you move it, and a tire being made of rubber/synthetics, won't it fill back out with the pressure from within? I've read some stuff on thread seperation occurs quicker from letting a boat trailer sit fully loaded.
As was pointed out, the portion of the tire in contact with the ground is distorted - but so is every other part of the tire because it is connected to that portion.
Everything "flatspots". The technical term is "creep". Some examples are springs that sag, the collapse of the World Trade Center, and of course, tires.
And while there are short term flatspots in tires, a tire that sits for long lengths of time can develop "permanent flatspots". I put that term in quotes, because I am not entirely convinced they are truly permanent - but I will concede the point for discussion purposes.
But I don't think flatspotting is an issue for trailers simply because flatspots cause vibrations and since no one is sitting in a trailer when it is moving (or at least they shouldn't).
Besides, trailer tires SHOULD be inflated to the max listed on the sidewall (because trailer manufacturers put on the smallest tires they can). Frankly, when the opportunity presents itself, I would be doing some upsizing on every trailer 9with some exceptions.)
And, No!, no one has connected the flatspot to tire failures. However, it has been pointed out that idle tires don't allow for the migration of those protective materials inside the rubber, so tires that sit for a long time tend to deteriorate faster (which seems counter intuitive, but true.)
