Mower revs up/down when cold
by DrRoughneck
08/24/16 12:14 AM
2015 dodge journey crossroad
by hardcore302
08/23/16 10:17 PM
Looking for new mechanical pencil
by Merkava_4
08/23/16 09:33 PM
Sewer gasses in bathroom
by sxg6
08/23/16 09:13 PM
I am a idiot, a fool or what? UOA coming soon!
by Vern_in_IL
08/23/16 08:57 PM
4ft LED T8 replacement bulbs 6.97$
by Rand
08/23/16 08:35 PM
Low cost sedan looks better than expensive one
by HTSS_TR
08/23/16 08:22 PM
Toyota red in motorcycles/snowmobi
les
by Altydoc
08/23/16 07:42 PM
Looking at some old posts
by Oldmoparguy1
08/23/16 07:35 PM
Towing a heavy trailer
by Donald
08/23/16 07:31 PM
Envelope Budget System
by GMFan
08/23/16 06:37 PM
Saving OPE after a flood?
by Geauxtiger
08/23/16 06:18 PM
Bigford545, FWR132, smancer, FJCurious, kburns
58899 Registered Users
37 registered (CharlieBauer, CKN, BrianF, Chris B., 5 invisible), 834 Guests and 6 Spiders online.
58899 Members
66 Forums
253477 Topics
Page 2 of 2 < 1 2
#3182103 - 11/08/13 11:00 AM Re: stp oil additive with zddp, and high mileage,good? [Re: KCJeep]
demarpaint Offline
Loc: NY
Originally Posted By: KCJeep
STP is peculiar, it thickens the oil but does not seem to have any adverse affect on start up, if anything starts are better with it. Doesn't make sense to me.
It's funny you mention it doesn't have adverse effects on start up. You brought me back in time, a long time. Years ago, many years, I used it in an old oil burning beater I bought to commute to college with when funds were low. I used it to slow consumption until I could afford a nicer car. Anyway I remember easy winter starts with it in the sump, God only knows how it flowed once the engine fired up, but it spun up real easy. Their advertising in the 60's and 70's touted its ability to make oil cling so cold starts were easier. I wonder if there was any truth to that? LOL
God Bless Our Troops
#3182167 - 11/08/13 12:35 PM Re: stp oil additive with zddp, and high mileage,good? [Re: demarpaint]
Plumber Offline
Loc: USA
I saw an ad on Ebay for sale a while back. STP had an illustration of an engine with a coat and hat on, covered in ice and snow.
#3182229 - 11/08/13 01:48 PM Re: stp oil additive with zddp, and high mileage,good? [Re: KCJeep]
Finz Offline
Loc: Northern NJ
Why do you say too thick? What happened?
God Bless America... We really need it about now
06 Odyssey
06 Civic coupe
05 Accord 2.4 sedan
11 Civic 1.8 sedan
98 Accord 2.3 sedan
#3185909 - 11/12/13 04:05 PM Re: stp oil additive with zddp, and high mileage,good? [Re: Finz]
KCJeep Offline
Loc: Mahzurrah!
A bottle in a 6 qt sump seems to work just fine, I've done it even in winter with no adverse affects whatsoever that I could detect. Like I mentioned if anything cold starts seemed easier. A bottle and half...lifter noise the first few minutes of running. Too much LOL.
I still want to run a single bottle and UOA sometime just out of curiousity.
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 63k, Ford Focus 116k, Chrysler Sebring 186k, Chrysler Concorde 120k
#3186283 - 11/13/13 03:49 AM Re: stp oil additive with zddp, and high mileage,good? [Re: ziggy]
default Offline
Loc: Michigan
Its a good way to thicken oil in an emergency, keep your lawnmower with a rod knock or oil burning issue running, shut up a noisy worn out FWD manual transaxle, etc. Beyond that its junk, definitely doesn't belong in anything in good working order.
#3186770 - 11/13/13 03:51 PM Re: stp oil additive with zddp, and high mileage,good? [Re: ziggy]
Mystic Offline
Loc: Colorado
I never cared much for STP Oil Treatment myself. It is basically thick oil with some chemical additives, and according to VOAs here it has a low amount of ZDDP. Newer vehicles require thinner oil and STP basically will just slow down oil consumption in an oil burner. Even in an oil burner a person might be better off just using thicker oil, like 20W50.
The one time I noticed a difference with STP was with a small car and the STP they used to have for small four cylinder engine cars. The car really did seem to run better.
I did not know they even still made STP.
Edited by Mystic (11/13/13 03:52 PM)
#3188027 - 11/14/13 08:36 PM Re: stp oil additive with zddp, and high mileage,good? [Re: Mystic]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
Absolutely. If you want a thicker oil, buy a thicker oil. If you want more ZDDP, buy an oil that has more (which is probably going to be thicker, too).
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3210252 - 12/08/13 10:41 AM Re: stp oil additive with zddp, and high mileage,good? [Re: ziggy]
Michael_P Offline
Loc: .
Question. If too much zinc can cause corrosion, why is zinc used as sacrificial anodes to protect marine metals such as aluminum and steel? Zinc would be the least noble metal of any metal found in an engine. What about the phosphorous that accompanies zinc, or the dithiophosphate compound? I have seen cam surfaces with rust pocks on them where the mechanic called it zinc poisoning. Furthermore, zinc corrosion seems to be magnified in a marine environment, or at least that is what I have been told. I am by no means a chemist, but know enough to sound dumb. My boat with over 2500 hours on it had zero internal corrosion on a teardown and it has seen 1600PPM zinc oil since day one. I have gone as far as 220 hours on an OCI as well.
#3210786 - 12/08/13 08:36 PM Re: stp oil additive with zddp, and high mileage,good? [Re: Michael_P]
Maybe Mola will read this and share his insights. As for the "limits" I place on ZDDP content, I'm probably being conservative. But, there is a point of diminishing returns even before spalling occurs, if I recall correctly.
As for zinc anodes to protect from corrosion versus spalling inside an engine, an aqueous solution is totally different from the environment inside an engine.
#3211630 - 12/09/13 07:24 PM Re: stp oil additive with zddp, and high mileage,good? [Re: Michael_P]
MolaKule Offline
Loc: Iowegia - USA
Cathodic protection is due to an electro-chemical effect and can hardly be compared to surface interactions in tribology.
Here is a good explanation of cathodic protection and sacrificial anodes:
Cathodic Protection
But you're right Michael, it the concentration of phosphorous and sulfur in the ZDDP molecule.
Zinc Dialkyl Dithiophosphates or ZDDP (or Dithiophosphoric Acid, O,O'-Isobutyl Amyl Ester, Zinc Salt ) is an ester which is used as an Anti-Wear agent and an Anti-Oxidant agent (a multifunctional additive) in oil additives and is composed of the elements of zinc, phosphorous, and sulfur.
When concentrations get above approx. 1200 ppm, and when under high moisture conditions and extremely high temperatures, there is the potential for the ZDDP molecule to split apart (via hydrolosis) and form acids attacking the metals as acids of sulfuric and phosphoric acid.
Marine oils, both gear lubes and PCMO's, as well as classic car and HDEO oils, have a higher level of anti-corrosion agents which tend to combat any acid attack. Most Marine engines also tend to run cooler, only to expel moisture at WOT when hot.
Edited by MolaKule (12/09/13 07:25 PM)
"Never buy flowers from a monk; only YOU can prevent florist friars." Smokey smile
#3212964 - 12/10/13 11:24 PM Re: stp oil additive with zddp, and high mileage,good? [Re: ziggy]
Michael_P Offline
Loc: .
Great explination MolaKule. Thanks.
So would a higher TBN combat this or are anti corrosion agents needed for this?
#3213458 - 12/11/13 01:50 PM Re: stp oil additive with zddp, and high mileage,good? [Re: ziggy]
MolaKule Offline
Loc: Iowegia - USA
The tbn is primarily deterrmined by the calcium or sodium detergents.
Quote:
Detergents (Surface Protective Additive): metallo-organic compounds of sodium, calcium, magnesium, boron phenolates, phosphates and sulfonates such as alkylbenzene sulfonic acids, alkylphenol sulfides, alkylsalacyclic acids; Lift deposits from surfaces to keep them suspended.
The corrosion inhibitors include some additional agents that include Metal Deactivators and Rust inhibitors:
Quote:
Metal Deactivator (Protective Additive): ZDDP, ZTDC, Moly TDC, Antimony TDC, family of diphenylamines and amides, and olefin sulfides, heterocyclic sulfur-nitrogen compounds; inhibits corrosive effects of oxygen with metals and decreases metal interaction with oxygen compounds to reduce oxidation of oil.
Rust Inhibitor (Surface Protective Additive): Barium sulfonates, amine phosphates, phosphordithioates, sodium thizoles (for coolants),
Chemistry of Additives
Page 2 of 2 < 1 2
