Is Legalizing Marijuana Safe????
by qwerty1234
05/30/16 03:44 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
05/30/16 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
05/30/16 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
kevinstoyhauler, jimx1169, W9HDG, LloydChristmass, dodge96
58019 Registered Users
30 registered (bbhero, bigt61, billt460, Astro14, dec219644, asand1, 2 invisible), 584 Guests and 333 Spiders online.
58019 Members
66 Forums
249584 Topics
#3131601 - 09/21/13 02:02 PM Marine 8V92 Detroit (trouble shooting)
ottomatic Offline
Loc: SE
60'Viking with 2 8V92's. Port engine runs perfect. Starboard engine won't go above 800rpms. No water coming out exhaust & was probably overheated by previous captain.
What kind of damage could owner be looking at. No blow-by. No water in oil. Just won't gain any rpms. Thoughts?????
Edited by ottomatic (09/21/13 02:03 PM)
14 JSW 6M 41,000 mi
06 Duramax,202,000 mi
01 XR650R Plated, Titled & 4 sale
#3131620 - 09/21/13 02:33 PM Re: Marine 8V92 Detroit (trouble shooting) [Re: ottomatic]
BigWrench9 Offline
Loc: Michigan USA
8V92's only need 2 things. Fuel and air. First pull the air filters, and test. If no change, pull the fuel filters, drain and check for water. Fill and re test. If no change, pull the fuel return line, if no good stream runs out while running, the fuel pump is more than likely the culprit. If all these tests prove ineffective, more than likely the "rack" is out of adjustment,(including the governor and dead stop), or the injectors may be suspect.
Also, if electric or manual shutdown, make sure shutdown lever is free enough to not be causing a "shutdown" condition.
#3131629 - 09/21/13 02:47 PM Re: Marine 8V92 Detroit (trouble shooting) [Re: BigWrench9]
ottomatic Offline
Loc: SE
Thanks. I'll try the above. What bothers me is there is no water coming out exhaust.
Also it's been a few years since I worked on a 2 stroke.
14 JSW 6M 41,000 mi
#3131649 - 09/21/13 03:19 PM Re: Marine 8V92 Detroit (trouble shooting) [Re: ottomatic]
Fleetmon Offline
Loc: Pa
check the blower drive
"In order to become the Master, a person must act as a servant."
NRA Endowment Member
#3131894 - 09/21/13 08:38 PM Re: Marine 8V92 Detroit (trouble shooting) [Re: ottomatic]
hattaresguy Offline
Loc: CT
Is 800rpm no load or under load?
The more pressing problem is that its not pumping water, that motor should heat right up, so I'm guessing 800rpm is no load? How did the motor overheat?
Check the impeller first, first step is getting it to run at temp and pump water.
Worst case its rebuild time, how many hours are on it?
Edited by hattaresguy (09/21/13 08:42 PM)
#3132260 - 09/22/13 10:10 AM Re: Marine 8V92 Detroit (trouble shooting) [Re: ottomatic]
NYEngineer Offline
Loc: NY, NY
Simplest thing ever on Detroits. Make sure the flap isn't closed on top of the blower.
I'm not positive marine engines have them but I know industrial gensets have them.
#3133397 - 09/23/13 12:18 PM Re: Marine 8V92 Detroit (trouble shooting) [Re: BigWrench9]
FL_Rob Offline
Loc: gulf coast FL.U.S.
Hi there..I see it's your first post.
Thank you for responding.My mos in the Army was 63Delta. Your statement on checks and re-checks is 100 percent invalueable... and thankyou again for becoming a member.
sorry I meant bigwrench9+
Edited by FL_Rob (09/23/13 12:29 PM)
Edit Reason: wrong name
