Mobil 1 jug sale at Meijer 2 day sale
by a1mfw
07/28/16 07:08 PM
Win 10 Problem
by GrtArtiste
07/28/16 07:06 PM
AC Shrader valve removal tool
by chiefsfan1
07/28/16 05:54 PM
Fuel pumps in carb engines
by Donald
07/28/16 05:40 PM
Changing Automatic Transmission Fluid
by Cristobal
07/28/16 05:26 PM
DELO 5W40 Synthetic UOA ?
by alanwayne1908
07/28/16 05:03 PM
DELO 5W40 Synthetic
by alanwayne1908
07/28/16 05:01 PM
93 J30t...worth it or not?
by Lolvoguy
07/28/16 04:56 PM
Chevron Supreme $2.29 Fred Meyer
by sprite1741
07/28/16 04:37 PM
Would you let a teenager house sit?
by VeeDubb
07/28/16 04:32 PM
FYI Dollar General has windshield fluid for $1 gal
by Rat407
07/28/16 03:54 PM
Got my Micro Green oil filter in from the 50% sale
by PolarisX
07/28/16 03:45 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
107 registered (alanwayne1908, a1mfw, aquariuscsm, AlaskaMike, 2165, 2015_PSD, 6 invisible), 1862 Guests and 11 Spiders online.
58632 Members
66 Forums
252368 Topics
Page 1 of 3 1 2 3 >
#3132590 - 09/22/13 03:54 PM Random no crank on 95 ram 5.9
ram_man Offline
Loc: southern mo
So it will start most the time. But once in a great while like. 1 in 20 starts maybe it'll go click. It may only click once or it may be 5 times in a row then it'll fire right up. I sat and kept starting it over and over with the lights on and with the lights on when it did it the lights stayed on.
The connections are all good battery has good voltage about 12.5
So I'm leaning to the starter but want to be sure before I replace it. What do you guys think?
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3132593 - 09/22/13 03:58 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
84zmyfavorite Offline
Loc: Wenatchee, W.A.
CPS.
#3132596 - 09/22/13 04:04 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
ram_man Offline
Loc: southern mo
Could that cause it to click when it doesnt start? The starter is what I believe is makes that click sound when it doesnt start.
#3132607 - 09/22/13 04:12 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
JHZR2 Offline
Loc: New Jersey
Does it click repeatedly or just once? If it clicks once like something is engaging and then nothing, Id bet a sticking something inside the starter.
If it clicks repeatedly, seems to me that means the starter doesnt have enough juice from the battery...
Inlaws had an issue where the alternator couldnt keep up in the hot weather in their accord, so the battery would draw. Then occasionally the starter wouldnt work, though everything looked and seemed to check out OK. It was only after a full load test was done that you could see what happened... Because otherwise all stats seemed OK.
#3132608 - 09/22/13 04:12 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
HardbodyLoyalist Offline
Loc: Lower Alabama
The click is probably coming from the starter relay.
1994 Nissan Hardbody -- Mobil 1 HM 5W30
1998 Ford F150 4WD -- Mobil 1 HM 5W30
2009 VW Jetta TDI -- Pentosin SuperPerformance III 5W30
#3132615 - 09/22/13 04:15 PM Re: Random no crank on 95 ram 5.9 [Re: JHZR2]
ram_man Offline
Loc: southern mo
it only clicks once.
#3132623 - 09/22/13 04:20 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
Falken Offline
Loc: Montreal, QC, Canada
Crank Position Sensor maybe.
Falken - Draftsperson
2010 Honda Fit DX-A in Black
Current Fill: Formula 1 Synthetic 5W20 SN, Wix 57356 Oil Filter, ATF DW-1
#3132634 - 09/22/13 04:29 PM Re: Random no crank on 95 ram 5.9 [Re: Falken]
Ken42 Offline
Loc: Palouse WA
A CPS will cause a no start but not prevent the engine from turning over.
That is why they are so hard to diagnoise
Current car: 2005 Hyundai Elantra: Current oil fill Schaeffers 9000 5W-30
#3132639 - 09/22/13 04:33 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
oldhp Offline
Loc: Southern Illinois
Sounds like starter is carbon tracking, or brushes are going bad.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4-Wife's Ride
#3132670 - 09/22/13 05:00 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
yonyon Offline
Loc: NJ, USA
If the connections are all good you need to load test the battery. If you don't have a load tester (toaster will work just fine) just use the starter and the very same voltmeter that told you you have 12.5V at the battery.
If the battery is good you get to replace the starter. If the new starter doesn't help you'll know that you were wrong about the connections being good.
#3132674 - 09/22/13 05:05 PM Re: Random no crank on 95 ram 5.9 [Re: yonyon]
ram_man Offline
Loc: southern mo
so how do you do a load test? You lost me at toaster lol
#3132676 - 09/22/13 05:08 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
Miller88 Offline
Loc: Onondaga County
Starter solenoid ... Although it seems to be more common on Fords.
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3132707 - 09/22/13 05:37 PM Re: Random no crank on 95 ram 5.9 [Re: 84zmyfavorite]
SLCraig Offline
Loc: London, ON, Canada
Originally Posted By: 84zmyfavorite
CPS.
Nope.
The CPS does not have the ability to not let the starter turn over. The starter is your problem, OR despite seeing good connections, there is a connection fault. The only 2 possibilities.
2010 Civic SI sedan 6MT
SynPower 5w30 | Fram Ultra | Pennzoil MTF
#3132717 - 09/22/13 05:42 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
ram_man Offline
Loc: southern mo
Could it be the battery by any slim chance
#3132719 - 09/22/13 05:44 PM Re: Random no crank on 95 ram 5.9 [Re: ram_man]
yonyon Offline
Loc: NJ, USA
A toaster is a thing like this. It's an inexpensive battery load tester that gets hot and makes smoke from burning off all the dust inside. They're not expensive so it's possible that someone you know has one. Failing that, read the voltage at the battery while holding the key in the crank position.
Page 1 of 3 1 2 3 >
