TechnoLoGs
Thread starter
Originally Posted By: aquariuscsm
Originally Posted By: Brit33
What to use in an old boxer engine then? Specs 10w40 or 10w50!
Clearances are not tight like on a modern engine.
Block flexes at high revs.
I use 15w50. Would you use anything thinner? 5w40 maybe.
Idle hot 10psi but at higher revs it reaches a healthy 60 psi.
5W20 wouldn't protect that engine??
This an honest question, and founding principle of BITOG.........
I think Dr. Haas's 0W-20s, which are, in fact, more like light-mid 30-weights if HTHS is used (the only way his writings make sense,) would, maybe...
But I don't know....................................
I summonLeviathan CATERHAM.
I summon
