Originally Posted By: Pablo
Yes I had the same exact problem a few years back with it. A lot of separation, even after pulling the rod out on the grease gun to relieve pressure.
Actually you had issues with the Series 2000 grease if recall correctly. Never heard of the Amsoil Multipurpose grease having separation issues.
Yes you're right! I was trying to remember exactly grease it was, thanks. I was under the impression it was a multi-purpose grease that was excellent for wheel bearings, which is what I bought it for. I was told at the time I was the only person ever to have a problem with that grease and it was supposed to be one of their best.
If you were the only person to have a problem with the Series 2000, then I would have to be the second person then.
This was around ten years ago or so, before I started pulling back on the rod to relieve the pressure after using the grease gun. It was because of this experience that I started doing it. I left the pressure with the Series 2000, and after a while I found a little mess where I stored the grease gun. The oil had separated and had dripped out of the gun. Not wanting to waste the remaining grease, and because it was supposed to be so good, I used it anyway, but I shouldn't have, as I found out later. I won't go into all the details, but basically there wasn't enough oil left in the grease to provide proper lubrication, and the results weren't pretty. Lesson learned.
