Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
Tire Rack now carries the Falken Azenis RT615k
by slacktide_bitog
05/05/16 07:30 PM
Walmart now carries Nokian tires
by slacktide_bitog
05/05/16 07:16 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
25 registered (car51, dlundblad, EchoTech1945, dec219644, d00df00d, Char Baby, 4 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248537 Topics
Page 1 of 2 1 2 >
#3129245 - 09/19/13 06:20 AM Keep carbon buildup out of the engine?
horse123 Offline
Loc: Lexington
2012 Audi A7 3.0T. Recently they sent out a notice about a warranty extension because of excessive carbon buildup on various parts of the engine. I'd much rather keep the carp out of it now, than pay someone $5000 to professionally decrap it later. What fuel additive could/should be used and how often?
Edited by horse123 (09/19/13 06:23 AM)
Have: 2012 Impreza 2.0i
Want: Colorado 2.8, E63 S wagon
#3129251 - 09/19/13 06:28 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
rfeir Offline
Loc: NY
May be related to its application of direct fuel injection. The industry is always working on new fuel formulations to address this issue. Use a Name Brand fuel.
RPF
#3129261 - 09/19/13 06:39 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
demarpaint Offline
Loc: NY
Good luck finding one that can be poured into the tank and help a DI engine stay carbon free if that particular engine design is prone to that problem. For the best results it would have to be fed via a vacuum line. An Inverse Oiler would probably help. Clevy and I mentioned this a few times. You might want to look into an Inverse Oiler.
God Bless Our Troops
#3129281 - 09/19/13 07:06 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
bourne Offline
Loc: Greenwood, IN
Top Teir 91~93 octane gas, occasional Redline SI-1/Techron treatment and weekly Italian tunes for a good 20~30 miles should keep it to the minimum.
2013 Kia Optima SX-L : Dealer Fill
2015 Chrysler 200S : Maxlife Full Syn 5w20 + CQ 94010
#3129290 - 09/19/13 07:25 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
badtlc Offline
Loc: KC
Any PEA cleaner (Techron, Gumout, Redline, Amsoil, etc.) used regularly will help keep the combustion chamber and injectors clean. That is an important step #1.
Then, keeping the RPMs up above 4500 or so for 20+min at a time will help keep the intake valves clean. This does not have to be done at high speeds, regular highway speeds (70-80mph) are fine. This has been shown to be very effective. I think steady speeds at highway are better than full throttle/high RPM applications due to the different combustion modes the DI engines have and some of these modes block of the EGR.
Edited by badtlc (09/19/13 07:26 AM)
2007 Ford Escape XLS 2.3L ATX, Trop Artic 5W30, MC Fl910s, 135k+
2015 Chrysler T&C, 40k+
#3129300 - 09/19/13 07:36 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
Miller88 Offline
Loc: Onondaga County
It does not matter what you put in the tank, the fuel does not go past in the intake valve in a DI engine, but crud sucked through the PCV is.
Spraying slight bits of water or italian tuneups seem to be good ideas.
DI engines usually have higher compression right? I'd be concerned about using something like seafoam in a higher compression engine!
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#3129310 - 09/19/13 07:46 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
stockrex Offline
Loc: Michigan
They have BG Chem tool but the best addy for keeping carbon out is NOT to drive it.
if you use any carbon dislodging addy, you will probably clog up stuff down the line.
remember, the hardest thing for an engine is to run when cold, so stop making short run throughout the day and make a long run,
07Ridgeline:33k,08Dmax:14k,10Fit:40k:90Toyota1Ton:88k
Oil Whisperer!*Fear the DINO*
#3129319 - 09/19/13 07:53 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
SEMI_287 Offline
Loc: Up State NY
PCV catch can perhaps?
2007 Chrysler 300C- M1 5w20 Wix filter
2014 Dodge Avenger- M1 AFE 0w20 M1 filter
2008 Mitsubishi Galant- PU SM 10w30 Wix filter
#3129388 - 09/19/13 09:08 AM Re: Keep carbon buildup out of the engine? [Re: SEMI_287]
badtlc Offline
Loc: KC
Catch cans do not help. Plenty of proof of that showing they do not help.
#3129391 - 09/19/13 09:10 AM Re: Keep carbon buildup out of the engine? [Re: Miller88]
badtlc Offline
Loc: KC
that isn't completely true. gas cleaners indirectly do help. The crud coming through the PCV comes from highly volatile oil. The oil becomes increasingly volatile due to fuel dilution. Using fuel system cleaners to keep the combustion chamber clean and the injectors clean, helps to insure better combustion and a more complete burn. This helps reduce the fuel that makes it to the oil and helps preserve oil quality and reduce PCV vapors.
#3130330 - 09/20/13 06:34 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
horse123 Offline
Loc: Lexington
So top tier gas is the best way?
#3130380 - 09/20/13 07:34 AM Re: Keep carbon buildup out of the engine? [Re: horse123]
badtlc Offline
Loc: KC
Quality fuel with high detergent levels is probably a good idea. Cheap fuels and regular use of cleaners can probably do as well.
#3130690 - 09/20/13 01:14 PM Re: Keep carbon buildup out of the engine? [Re: horse123]
horse123 Offline
Loc: Lexington
^ obvious spam account is obvious
#3130698 - 09/20/13 01:20 PM Re: Keep carbon buildup out of the engine? [Re: horse123]
kimandsally Offline
Loc: United Kingdom
Hi I have contacted the administrator of this site explaining what had happened, I DO NOT have to explain to you, either believe or not DO NOT accuse me of something I have never been EVER on ANY forum and I have been around the internet for 20 years using the same name, google me and then come back and apolagise.
PS
I love it you ask for help then accuse people who have spent their time trying to help of lying. Your best bet is to ignore what everyone says ans go wreck you car in you own way that way you will have no one else to blame.
One thing for sure I wouldn't type another letter to help you even if you were on fire!
Edited by kimandsally (09/20/13 01:31 PM)
#3130720 - 09/20/13 01:51 PM Re: Keep carbon buildup out of the engine? [Re: horse123]
Trajan Offline
Loc: SE PA
I think it's the non sponsor link that triggered the response.
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
Page 1 of 2 1 2 >
