toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
Permatex Silicone Tape
by Warstud
06/24/16 06:28 PM
Walnut Grips Really Make A Difference !
by billt460
06/24/16 06:25 PM
PC freezing up when streaming sports
by sleepery
06/24/16 05:52 PM
Use a heavier oil or HM oil?
by mclasser
06/24/16 05:42 PM
Kendall GT-1 (w/titanium?) 20w-50 for airheads
by Samzone
06/24/16 05:20 PM
Engaged
by LoneRanger
06/24/16 04:49 PM
What stores still carry quality US-made fuel hose?
by JHZR2
06/24/16 04:25 PM
Looking For A New Natural Gas 6 Burner Barbecue...
by crazyoildude
06/24/16 04:25 PM
Autolite spark plug rebate
by Need4racin
06/24/16 04:20 PM
Can Am Spyder
by Panzerman
06/24/16 04:17 PM
Koloa, codeman021, chryslerconcorde, VolCntry73, OilyWaterMIXER
58254 Registered Users
89 registered (artificialist, atlsrt44, adolan21, AnthemBassMan, AandPDan, b1amgm47, 8 invisible), 1575 Guests and 12 Spiders online.
58254 Members
66 Forums
250759 Topics
Page 1 of 2 1 2 >
#3128408 - 09/18/13 08:58 AM Multimeter use on spark plug wires
TechnoLoGs Offline
Loc: Call it NNJ
As to testing them. I have an 8mm coil wire, looks to be in good shape, slightly dirty contacts but I have "Battery cleaner" (the kind that foams up.) I also have a multimeter. I am asking if there is a way to determine if this wire is good by measuring its resistance.
Any normally accepted values for this kind of thing, in Ohms or kOhms or milli-Ohms or ?
We are re-doing the tune-up on the truck.
1993 Chevrolet S-10 Blazer 4.3, the Frankenblazer - 184,440mi. 10/22/13 - WPP Supertech 10W-40
12,359 10/22 12,361 10/23 12,365 10/24 12,369 10/25
#3128416 - 09/18/13 09:04 AM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
punisher Offline
Loc: snowblind in TX
In ancient times there was an "ohms/foot" spec for wires. You would hook up your DVOM, or an actual analog meter (watch that needle) and flex the wire and look to see if everything was in spec. If I were doing it now, I would just ohm the wire, and compare it to the others and look for something way out of spec. Truth is, ohming a wire isn't the best test in the world, better than nothing, but not a great test.
#3128432 - 09/18/13 09:35 AM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
TFB1 Offline
Loc: VA
If one looks hard enough there is still ohms per foot given for most wires, common for racers to "ohm out" their wires... The spiral wound wires will have a very low resistance vs the carbon types...
#3128478 - 09/18/13 10:26 AM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
dparm Offline
Loc: Chicago, IL
Factory service manual (the ones that dealer techs use) should have the minimum accepted value for resistance of the wire. My old Integra's did.
2011 BMW M3 sedan ZCP
#3128482 - 09/18/13 10:29 AM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
eljefino Offline
Loc: ME
You might need a "megger" eg mega-ohm meter. Your average radio shack $20 model might not do it.
#3128539 - 09/18/13 11:27 AM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
MolaKule Offline
Loc: Iowegia - USA
Many OEM resistance spark plug wires using carbon conductors have around 5,000 to 15,000 ohms of resistance per foot, very much within the measuring capabilities of a common analog VOM or a DVM.
Specialty racing wires with high copper content or special construction will have much lower resistance.
MSD says this:
Quote:
Heli-Core Wires (Blue):
150 - 1,200 ohms per foot
8.5mm Super Conductor (Red):
40 - 50 ohms per foot
If you do not know the specification for your wires, measure the resistance of each wire. Remember to divide the length of the wire by 12 to get a "per foot" measurement. If one wire is out of that average spec, it is at fault
Solid Core Wires: You cannot run Solid Core Spark Plug Wires with an MSD Ignition Control. Solid Core wires do not suppress any Electro Magnetic Interference (EMI) which will interfere with electronics or rev limiters on your vehicle. A suppression style or spiral wound spark plug wire MUST be used.
Some guy on LS1 says he tested various wires:
Quote:
So here's my test. All wires were tested at least 3 times to be sure I have accurate numbers here. Remember, they were all 12.5 inches long. I tested next to a radio but did not pick up any static from any of these wires.
stock LS1 6 in. - 351 ohms
Granatelli 8mm Steel Solid Core Cable - 0.1 ohms
MSD 8.5mm Super Conductor - 71.6 ohms
Accel 8.8 300+ Ferro-Spiral Race Wire - 166.1 ohms
Jacobs Electronics EnergyCore 8.5mm - 178.3 oms
Taylor Spiro Pro 8mm Silicone - 301 ohms
Mallory Pro Sidewinder 8mm Silicone Suppression Wire - 313 ohms
Moroso Blue Maz Spiral Core 8mm - 661 ohms
Magnecor KV85 Competiton 2.5mm - 2053 ohms
Edited by MolaKule (09/18/13 11:41 AM)
Why do seagulls fly over the sea? Because if they flew over the beach they would be called, "Beaguls." smile
#3128671 - 09/18/13 02:13 PM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
meep Offline
Loc: Southeast
ohming them ensures they are conducting and not arcing inside. obviously the long wires will have more resistance, and this is ok.
It will not catch early breakdown in the insulating jacket, where a wire may be arcing to ground and causing a misfire.
2006 Tundra 2wd
2002 MDX (wifey!)
2005 s60 2.4L
#3128680 - 09/18/13 02:20 PM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
dishdude Offline
Loc: Phoenix
I thought you replaced the wires?
#3128693 - 09/18/13 02:30 PM Re: Multimeter use on spark plug wires [Re: dparm]
stephen9666 Offline
Loc: USA
This.
I know I've seen this spec in my FSMs.
#3128992 - 09/18/13 07:55 PM Re: Multimeter use on spark plug wires [Re: meep]
JetStar Offline
Loc: Flatlands of Indiana
Bingo, "Any good" means that they are conductive where they should be and don't arc through the insulation to ground. Both will cause misfire. To test the insulation properties, you would need a Hi-pot / dielectric tester capable of at least 20 Kv and a ground rod to sweep the exterior looking for flashover. probably not worth the hassle. Probably easier to check them out for arcing at night.
Edited by JetStar (09/18/13 07:56 PM)
My weakness is I love all motorcycles regardless of brand
2016 Suzuki DR650
2015 Road Glide
2007 Yamaha FZ1
1978 Suzuki GS1000 (now 1085)
#3129060 - 09/18/13 08:53 PM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
TechnoLoGs Offline
Loc: Call it NNJ
^^^ I just misted water onto all electricals at night in the dark and I saw NO light show, AT ALL! This is desired result, yes?
#3129122 - 09/18/13 10:28 PM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
punisher Offline
You know, we had $100k+ of electrical/ignition/computer testers in the shop, and a spray bottle was still the fastest/easiest way to find a bad wire.
#3129199 - 09/19/13 01:33 AM Re: Multimeter use on spark plug wires [Re: TechnoLoGs]
ram_man Offline
Loc: southern mo
That is the redneck way. It tests the wires insulation. Honeslty when I check them I do them all and if one has a resistance way higher than the rest I get all new. As long as they are fairly even accross the board theyre ok.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3129354 - 09/19/13 08:22 AM Re: Multimeter use on spark plug wires [Re: ram_man]
dishdude Offline
Loc: Phoenix
Sometimes the simplest test is the best.
#3129438 - 09/19/13 10:07 AM Re: Multimeter use on spark plug wires [Re: dishdude]
hsd Offline
Loc: NE
Just run fingers along the wires while its running cry
Page 1 of 2 1 2 >
