Myliftstand alternative jack stand
by momo
06/26/16 03:33 PM
Kmart sale on Smitty's oil and ATF
by slacktide_bitog
06/26/16 02:53 PM
Napa master pack oil filter price
by Electromotive
06/26/16 02:39 PM
Local Big Lots still has Valvoline next gen 10w30
by Electromotive
06/26/16 01:25 PM
Best Value Differential Oil 75W-90
by KevinP
06/26/16 01:02 PM
kohler 17hp . changed oil , now will not run
by chad8
06/26/16 12:32 PM
Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
06/26/16 11:49 AM
Suggestions for 94 Lexus LS400 ATF
by Gasbuggy
06/26/16 11:23 AM
GOST Diesel fueln
by m37charlie
06/26/16 11:10 AM
Old interesting finds
by car51
06/26/16 10:53 AM
Filling nail holes in drywall
by Drew99GT
06/26/16 10:47 AM
1987 ford 460 motorhome, which oil to use?
by digler
06/26/16 10:30 AM
Ruturaj, derfderfgoose, ssnead, mtrev, redtacoma
58277 Registered Users
78 registered (BigD1, b1amgm47, 87sammy, 2015_PSD, Al, Bandito440, 9 invisible), 2028 Guests and 11 Spiders online.
58277 Members
66 Forums
250840 Topics
Page 2 of 2 < 1 2
#3129334 - 09/19/13 08:09 AM Re: Questions about different oil in same engines. [Re: Spudislander]
Spudislander Offline
Loc: Canada
Originally Posted By: Spudislander
Originally Posted By: Clevy
The ESP oil is formulated for the emissions equipment. It has less of some elements that could possible shorten the life of you're emissions equipment.
I believe the 0w oils are TYPICALLY more advanced than their 5w- counterparts.
Do the 0w oils have better formulation for the emissions equipment vs the 5w20 motor oils? I have a 2013 Mazda 3 with 2.0L motor and Mazda recommends 0w20 whereas the recommended oil for my previous (2009) Mazda 3 with the same motor was 5w20. I was thinking about using some 5w20 Valvoline Synpower which is on sale at the local Walmart. However, if its formulation is not as good for protecting the emissions equipment I will not use it.
Sorry, just realized that I was reading under the Diesel section of the forum. I assume this does not apply the same to gasoline engines.
#3129343 - 09/19/13 08:18 AM Re: Questions about different oil in same engines. [Re: kimandsally]
CivicLX Offline
Loc: FL
Originally Posted By: kimandsally
Hi I'm new so please be gentle.
I have a Ford 2.0l PSA DW engine Ford recommend this: Mobil Super 3000 X1 Formula FE 5W-30
But with the same engine in another car V70 2.0D (D4204T - 100kW) the recommend this:
Mobil Super 3000 X1 Formula FE 5W-30 or this: MOBIL 1 ESP 0W-30
But the same engine in this 407 2.0 HDi 16V FAP/DPF Coupe (DW10BTED4 - 103kW) they recommend this: MOBIL 1 ESP FORMULA 5W-30.
I understand the basics of oil and I get Ford want the use the FE to save fuel but what I don't understand is why Peugeot and Citroen both use the Mobil 1 ESP 5W 30.
I want to use the Mobil 1 ESP 5W 30 I don't care about the minuscule amount fuel I will lose I want the engine to run longer as it will be a while until I can afford to buy another car so I want this to live a long and reliable life.
I know the Peugeots and Citroens use this system:
* a post-injection of fuel in the expansion phase, which generates post-combustion in the cylinder and raises the temperature of the gases by 200 C to 250 C, to around 350C to 400 C.
* additional post-combustion generated by an oxidation catalyser placed upstream of the filter, which treats the unburned hydrocarbons from the post-injection phase. The temperature may increase by a further 100 C, up to 450C or 500 C.
* the fuel additive Eolys fuel additive. This additive lowers the natural particle combustion temperature to 450 C.
And my Ford doesn't use the Eloys fuel additive but it says: The DPF regeneration can be done both actively and passively.
Mobil 1 ESP 5W-30 is for the cars have DPF and that's why it is recommended for your Citroen and Peugeot. However, this oil does not certify Ford 913-C.
For your Ford, either Mobil 1 0W-30 Fuel economy or Mobil Super 3000 X1 Formula FE 5W-30 will be a good choice as they certify Ford 913-C.
2004 Honda Civic Lx [105k] Mobil1 High Mileage 5w-20
#3129423 - 09/19/13 09:46 AM Re: Questions about different oil in same engines. [Re: Spudislander]
jayg Offline
Loc: Anchorage, AK
Right your gas car does not have a DPF that is sensitive to ash deposits.
'15 Toyota Prius C TGMO 0w20
'91 Toyota Land Cruiser VWB 5w30
'73 Datsun 240Z 4sp Vintage QS 10w40 from '73 in the sump
Page 2 of 2 < 1 2
