Help with iphone on the home network
by buck91
05/06/16 06:45 AM
2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
83 registered (askani79705, AirgunSavant, aquariuscsm, 97f150, Asterix, 2015_PSD, 10 invisible), 0 Guests and 0 Spiders online.
57814 Members
66 Forums
248539 Topics
#3129254 - 09/19/13 06:30 AM Blue Devil Pour-N-Go (new formula)
TechnoLoGs Offline
Loc: Call it NNJ
Was curious.. Seeing as how it is a coolant additive, how does Blue Devil Pour-N-Go work? How effective against leaks?
http://www.gobluedevil.com/pourngo.html
With this one, it says you do not have to:
- Flush
- Remove antifreeze
- Wait after the 50 minutes.
Therefore, it seems more of a sealer, more workable to most people.
What is your all opinion of it?
#3129267 - 09/19/13 06:54 AM Re: Blue Devil Pour-N-Go (new formula) [Re: TechnoLoGs]
JHZR2 Offline
Loc: New Jersey
Fix your leak the right way. In general, the fewer steps or less involved the approach, the more temporary it is. That is mainly due to the ability for it to seep and cure (which even if done the long way with a removal of AF, pressurization of the system, seepage into the leaks, curing, etc. is still probably a fairly temporary approach). I doubt if any of these, even the more thorough ones are true long-term fixes. Ill bet they are more for used car lots to sell a vehicle to a sucker.
#3129270 - 09/19/13 06:55 AM Re: Blue Devil Pour-N-Go (new formula) [Re: TechnoLoGs]
toneydoc Offline
Loc: War Eagle
Never used it myself. But I am always suspect of these type sealers that are added to fluids. I have tried others in radiators and nothing has ever worked except to change out the bad part or change gaskets.
1994 Jeep 145k Castrol 0w40
2014 Camry 13k TGMO 0w20
2010 Sebring 39k Penn Plat 5w20
2014 HD Ultra 16k Valv20w50
2012 Toyota Rav4 21k Mobil 1 0w30AFE
#3129275 - 09/19/13 07:02 AM Re: Blue Devil Pour-N-Go (new formula) [Re: TechnoLoGs]
Shannow Offline
Loc: Oz
MSDS says that the active ingredient is Sodium silicate...that will work, and can be effective...but...
A head gasket leak is cylinder to coolant (or worse), there's nothing making the goop flow to the high pressure.
The goop needs to be raised to 120C or thereabouts to form "glass" and seal what it can. It will solidify wherever it sees that temperature.
the "or worse" part is the bit that gets to be interesting.
One of the "worse" is that when you shut it off, the goop leaks into the cylinder (pressure goes that way on shutoff), and the "goop" gets into the cylinder.
The other "worse" is that it gets into the oil, and finds its 120C activation temperature somewhere around a valve guide or a piston ring.
Sodium silicate is what was poured into the sumps of those "clunker" programme vehicles in order to destroy the engine.
