Y'all need neighbors like this one.
by simple_gifts
1 minute 55 seconds ago
F-106 Fumoto Valve
by DBMaster
46 minutes 21 seconds ago
Propane/Oxygen vs Oxygen/acetylene
by Vern_in_IL
56 minutes 10 seconds ago
CarQuest Red 85372 Cut open
by blupupher
58 minutes 58 seconds ago
Battery dead on new car
by Leo99
Today at 05:22 PM
1997 Saturn P0326 No power
by nwjones18
Today at 04:29 PM
Can I use lower weight ?
by ST2008
Today at 04:25 PM
Amsoil 0W-30 Honda S2000 40,259 OCI w/bypass
by slalom44
Today at 03:32 PM
Holdup
by Whitewolf
Today at 03:14 PM
boosting diesel perf using propane/CNG/meth added
by columnshift
Today at 03:04 PM
HP for '96 Toyota Corolla?
by Benzadmiral
Today at 03:04 PM
Gene Wilder Dies at 83
by John_Conrad
Today at 02:52 PM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
80 registered (AnthemBassMan, 4WD, Bandito440, AlaskaMike, Astro_Guy, asiancivicmaniac, 10 invisible), 1629 Guests and 6 Spiders online.
58952 Members
66 Forums
253739 Topics
Page 1 of 2 1 2 >
#3127237 - 09/17/13 06:58 AM Is there a snake oil that'll really remove carbon?
j_mac Offline
Loc: wv
Is there really a snake oil I can pour into the gas tank that will clean carbon deposits from the combustion chamber and piston crown? Or do I have to get into some kind of heavy back to back (expensive) Techron regimen to get it done?
I don't like the "nuclear option" like some of the Seafoam videos I've seen. Seems like a good way to plug the catalytic converter.
Heck, If I could temporarily remove the converter with no ill effects like the old days, then I would "go nuclear" on it with a simple water treatment. I used to do it all the time with dramatic (good) results in old Hondas and Mustangs. Just a massive dose of tap water into the throttle body while revving the engine to 3000 RPM would do the trick. About 2-4 liters from an old coke bottle within just a few minutes. Steam and soot pouring out the back. But the car I'm wanting to fix (stop it from pinging) is only 2 years old and under warranty. Its a 2012 Hyundai Accent.
I just want to pour something into the tank that will dissolve/burn/break away the carbon buildup in the combustion space.
Does such a snake oil exist?
And before you say it, the dealer will look at me real stupid, try to make the problem out to be my fault, and then have a minion mechanic "go through the motions" and then tell me that "Its normal for the car to make a 'death rattling' noise."
I need help figuring out this one guys.
HELP!
Edited by j_mac (09/17/13 07:02 AM)
#3127242 - 09/17/13 07:13 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
rfeir Offline
Loc: NY
Just use a quality name brand fuel and an SN rated motor oil.
RPF
#3127254 - 09/17/13 07:27 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
Phishin Offline
Loc: Indiana
It's not that expensive, but I've had good results with Gumout Regane High Mileage. It's about $5/bottle at my Walmart. It not only fixes pings, but it's so good at removing carbon, that it helps keep my plugs from fouling in my 1990 K1500.
I'd buy two or three bottles. It's only $10-$15.
If you just buy 2 bottles, put them in at the same time. Fill your tank with gas. Drive normal. Short trips are fine (even preferred). Letting the Regane wet the combustion area, and sit for awhile, and restart is great. That's why I say short trips are preferred. Drive until you reach a half tank of fuel. Refill your tank. Drive until you reach another half tank, refill with fuel. Drive until empty.
It's always worked well for me.
My theory is with this method is you drive a half tank at 2X concentration, and then a half tank at 1X concentration, and then a full tank at 0.5X concentration.
If you buy a third bottle.....I add the third bottle the before I refill the first half tank....so you basically run a full tank of fuel for 2X, than a half at 1X, and then a full tank at 0.5X.
2010 Accord-LX K24: PU 5w30
2009 Subaru Forester 2.5X: M1 TDT
1990 Chevy K1500 350TBI: Frankenbrew
2008 Ruckus 50ccGET: M1R Mix
#3127270 - 09/17/13 07:51 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
Brent_G Offline
Loc: Aberdeen SD
Have you tried an Italian tuneup? Some time with your foot on the floor can do wonders for carbon removal.
05 Grand Prix GTP
01 Ford F150
06 Yamaha R1
69 Roadrunner 528 Hemi
68 Dart GTS 512
71 Superbee's 440 and 383
87 Camaro 540 BBC
#3127273 - 09/17/13 07:58 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
danthaman1980 Offline
Loc: SE Wisconsin
I have a friend that swears by RxP for decarbonizing combustion chambers. Personally I think it -might- be snake oil, but it might be worth a shot. I've had good luck alternating Regane and Techron on back-to-back tanks.
2003 Chevy Silverado 1500 5.3 LS Quadrasteer ~224,000 miles; PU 5W-30
2014 Mazda6 Sport 2.5 Skyactiv ~32,000 miles; PP 0W-20
#3127275 - 09/17/13 08:00 AM Re: Is there a snake oil that'll really remove carbon? [Re: Brent_G]
Miller88 Offline
Loc: Onondaga County
Proven to be effective and really fun!
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3127289 - 09/17/13 08:21 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Water.
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3127290 - 09/17/13 08:22 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
c502cid Offline
Loc: Elizabeth. Colorado
99 Durango with a 360. Always pinged on regular fuel in higher temperatures or with A/C on. I started adding MMO to the gas two years ago. Took a couple of months but it hasn't pinged once since.
I'm crediting the MMO cleaning the carbon off.
15 Chev Trax AWD
02 GMC 3500 4x4 8.1/Allison
00 Chev Blazer
00 Honda Civic
84 Chev K30 454 EFI
71 GMC Jimmy 502 RamJet
08 Kawasaki BruteForce 750
#3127296 - 09/17/13 08:27 AM Re: Is there a snake oil that'll really remove carbon? [Re: ARCOgraphite]
demarpaint Offline
Loc: NY
Originally Posted By: ARCOgraphite
Water.
+1 It works like a champ, via a vacuum line. Just use hot water, and care not to hydro-lock the engine.
God Bless Our Troops
#3127303 - 09/17/13 08:31 AM Re: Is there a snake oil that'll really remove carbon? [Re: ARCOgraphite]
Andy636 Offline
Loc: Romania
Water.
+1
#3127322 - 09/17/13 08:51 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
gregk24 Offline
Loc: FL, USA
Just use Techron in the gas tank, its not that expensive.
2012 Honda Accord EX-L
Taffeta White - Ivory
40,xxx miles
PPPP 0w20 / Fram Ultra
#3127332 - 09/17/13 09:00 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
Donald Offline
Loc: Upstate NY
Techron or other PEA based cleaners are designed to remove carbon deposits inside the cylinder. Dealers do use Techron, I would not consider it a snake oil. Will it be an instant fix, probably not.
How do you know you have carbon deposits. Inspection camera?
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3127351 - 09/17/13 09:15 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
AVB Offline
Loc: Georgia
I don't know about Hyundai, but GM, Chrysler and I think Ford all have a aerosol combustion chamber cleaner. If the dealer has something similar they should do a treatment under warranty. There could even be updated programming for it.
#3127422 - 09/17/13 10:33 AM Re: Is there a snake oil that'll really remove carbon? [Re: j_mac]
SteveSRT8 Online   content
Loc: Sunny Florida
Our fleet trucks used to regularly develop 'carbon knock'. Sounds a lot like piston slap, but a little louder and doesn't go away quickly from a cold start.
Kreen in the fuel cured it in minutes, period. Great product for carbon, IMO.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3129246 - 09/19/13 06:22 AM Re: Is there a snake oil that'll really remove carbon? [Re: demarpaint]
TechnoLoGs Offline
Loc: Call it NNJ
Water.
Also make sure it is hot engine, yes?
1993 Chevrolet S-10 Blazer 4.3, the Frankenblazer - 184,440mi. 10/22/13 - WPP Supertech 10W-40
12,359 10/22 12,361 10/23 12,365 10/24 12,369 10/25
Page 1 of 2 1 2 >
