Full brand oil filter
by RRLJR
05/27/16 05:31 AM
Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
05/26/16 10:13 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
65 registered (A_Harman, 2015_PSD, 69GTX, Astro_Guy, aquariuscsm, badtlc, 6 invisible), 1046 Guests and 311 Spiders online.
57996 Members
66 Forums
249471 Topics
Page 1 of 2 1 2 >
#3127240 - 09/17/13 07:09 AM Should I use Maxlife?
Lubener Offline
Loc: Ohio
As I posted before, my 92 Dodge with 2.5 (152K miles)engine burns (not leaks)a quart every 800 miles. It was suggested to try Maxlife. I have always used dino oil. I see Maxlife is semi synthetic. Is it a good idea to try this considering a synthetic has never been used in this engine? I am afraid of making the problem worse.
The "thinking" man's friend.
#3127244 - 09/17/13 07:14 AM Re: Should I use Maxlife? [Re: Lubener]
Zero Offline
Loc: WV
Won't hurt a thing and if you don't like it, you can safely go back to dino.
(Insert long list of automobiles, oil and oil filters here.)
#3127245 - 09/17/13 07:15 AM Re: Should I use Maxlife? [Re: Lubener]
rfeir Offline
Loc: NY
Chrysler considers 800 miles per qt. normal usage.
RPF
#3127266 - 09/17/13 07:42 AM Re: Should I use Maxlife? [Re: Lubener]
Bandito440 Offline
Loc: NYS
Go for it. You won't hurt a thing. You can even give 10w-40 a try if you don't get sufficient results from 5w-30.
'14 Grand Cherokee EcoDiesel
Pennzoil Euro L & OEM filter
#3127276 - 09/17/13 08:01 AM Re: Should I use Maxlife? [Re: Lubener]
Voltmaster Offline
Loc: California
Your consumption isnt alot considering engine and milage....
Maxlife has helped alot of people here , why not try it?
Using quality oil cannot hurt a modern car.
#3127280 - 09/17/13 08:09 AM Re: Should I use Maxlife? [Re: Lubener]
danthaman1980 Offline
Loc: SE Wisconsin
Wow, 1 quart per 800 miles. Geez, I think I'd be using the CHEAPEST 10W-40 I could get my hands on. Granted, if you can slow down that consumption with a good HM oil, it might be worth it. Maxlife 10W-40 or Defy 10W-30/10W-40.
Don't worry about the semi-synthetic nonsense. Most oils are basically semi-synthetic these days.
2003 Chevy Silverado 1500 5.3 LS Quadrasteer ~224,000 miles; PU 5W-30
2014 Mazda6 Sport 2.5 Skyactiv ~32,000 miles; PP 0W-20
#3127286 - 09/17/13 08:19 AM Re: Should I use Maxlife? [Re: rfeir]
demarpaint Offline
Loc: NY
Some companies consider 500 miles per qt normal, it all depends. If you go in complaining you use a qt/1,000 miles they'll tell you 800 is normal, if you tell them you use a qt in 800 miles they'll tell you 500 is normal. LOL After 500 you might have a shot at them actually doing something, once again it all depends.
God Bless Our Troops
#3127287 - 09/17/13 08:19 AM Re: Should I use Maxlife? [Re: Lubener]
Char Baby Offline
Loc: Western NY
I'd stay with 5W30 or 10W30 for the 2.5L. This is what I used in my 2.2's & 2.5's in the past though, not HM Oils just regular dino.
I am currently using 5W30 in my 1980 Firebird FORMULA V8 which, has/had some leaks/drips and mild blowby. I used to put in 1/2 qt per 500 miles or so. Now after using MaxLife for 3 years and Defy for the past 2 years, there are still some drips of oil(garage/driveway) but, I don't have to topoff from summer to summer.
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3127759 - 09/17/13 04:26 PM Re: Should I use Maxlife? [Re: Lubener]
Merkava_4 Offline
Loc: Clovis, CA
If it burns a quart every 800 miles then you probably need to go up in viscosity.
#3127786 - 09/17/13 04:54 PM Re: Should I use Maxlife? [Re: Lubener]
901Memphis Offline
Loc: Northern Kentucky
Don't mess with the viscosity. You can safely try maxlife, just remember it may take a few oil changes to notice a difference, so don't condemn it after one oci.
I would recommend M1 High Mileage 5w30, it's one of my favorite hm oils and it's on the upper end of the viscosity range so it's benefits might be greater while maintaining 30 weight range.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3128214 - 09/18/13 04:45 AM Re: Should I use Maxlife? [Re: 901Memphis]
Char Baby Offline
Loc: Western NY
Agreed^^^
I have a car that I only drive during the summer months('80 Firebird FORMULA V8). Original Owner/33 years! This engine had probably experienced those drips/leaks or even some blowby for at least 10 of those years.
I believe it took 4 summers/OCI's to notice the oil drips slowing down(using MaxLife). And the consumption, even though the drips hadn't quite stopped, was gone completely as I no longer have to topoff with oil all summer long. I must have also had some blowby since I only put on about 500-700 miles/summer and I was adding ~ 1/2 qt during those miles though, no tailpipe smoke smile
I last change the Oil/Filter in July 2012 and still have not had to topoff with oil. I may change the oil prior to the Winter storage...or not! Maybe only in the Spring '14. Oil is still very clean with only about 900 miles on this OCI
I am currently using another HM oil(DEFY) with continued success and I like it's smoother operation as well. I will continue to use either of these HM oils in this car as I have noticed a dramitic slow down of oil drips and the consumption is gone!
In addition, with vehicles driven more often than a summer car, I'd expect to see results of HM oils much sooner than my particular 4 years. Several OCI(or a years worth) would be normal IMHO!
Edited by Char Baby (09/18/13 04:57 AM)
"Retired"
#3128239 - 09/18/13 05:18 AM Re: Should I use Maxlife? [Re: Char Baby]
Char Baby Offline
Loc: Western NY
Agreed^^^
I should add that I use 5W30 in this engine(4.9L/301cid V8 w/4bbl Rochester). Though the OM mentions many grades of oil from 5W30 to 20W50, the engine doesn't seem to require anything beyond a 10W30.
"Retired"
#3128261 - 09/18/13 06:13 AM Re: Should I use Maxlife? [Re: Lubener]
Jay1981 Offline
Loc: Michigan
No, it won't hurt your vehicle to try Maxlife and its a great oil, but I don't see how it would help with your oil burning issue. I have used it in several vehicles that leaked oil and it worked great, but its designed to help with leaks (seal conditioners) If it were my car, I think I would try a 10w40 (like WM supertech) or maybe even a 5w40 as it would be better for cold winter starts.
Formerly "T4R"
2007 Chrysler T&C Touring, 98k
2010 Ford F-150 STX, 76k
#3128360 - 09/18/13 08:14 AM Re: Should I use Maxlife? [Re: Lubener]
FZ1 Offline
Loc: Texas
The reason HM oils help with burning is greater Density. Density and Grade are not the same thing. Start HM oils at the same grade you are currently running. Ideal is running the oem spec grade in a HM oil with no burn.
#3128366 - 09/18/13 08:23 AM Re: Should I use Maxlife? [Re: Jay1981]
TechnoLoGs Offline
Loc: Call it NNJ
Doesnt it "condition" those seals by "destroying" them?
I think that may be why so many dont use High Mileage oils...
Or, just a Group II like Castrol GTX? .. Does that help?
1993 Chevrolet S-10 Blazer 4.3, the Frankenblazer - 184,440mi. 10/22/13 - WPP Supertech 10W-40
12,359 10/22 12,361 10/23 12,365 10/24 12,369 10/25
Page 1 of 2 1 2 >
