Mobil 1 oil filter quality
by dgunay
02/09/16 03:34 PM
help replacing door pins on a 98 corolla
by ziggy
02/09/16 03:26 PM
Bought an oil filter today.
by Taildragger
02/09/16 03:14 PM
15' Audi A4 quattro 2.0T Valvoline 0W40 7510 miles
by skyactiv
02/09/16 02:53 PM
Dodge Grand Caravan - Need Some Info
by Nick1994
02/09/16 02:47 PM
Oil for 1997 4runner with 300K
by claluja
02/09/16 12:54 PM
2003-2009 Lexus GX 470 Rear shocks for sale
by exman123
02/09/16 12:09 PM
Maintenance on a Mint Low Mileage 2001 S2000
by Thugzy
02/09/16 11:54 AM
AutoZone Game...cash and gift cards
by eddielasvegas
02/09/16 11:51 AM
Dual platinum and iridium sparkplugs vs. standard
by DrRoughneck
02/09/16 11:31 AM
Kendall Super-Dxa 15W-40 SynBlend
by 2015_PSD
02/09/16 10:05 AM
2015 Ford F-250 6.7L MC Filter (9,800 miles)
by 2015_PSD
02/09/16 10:01 AM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
100 registered (2009Edge, 2015_PSD, 901Memphis, 01_celica_gt, 440Magnum, 97K15004WD, 10 invisible), 1656 Guests and 101 Spiders online.
56865 Members
66 Forums
244453 Topics
Page 1 of 3 1 2 3 >
#3127832 - 09/17/13 05:49 PM Temp issues again
ram_man Offline
Loc: southern mo
So I replaced the thermostat in the saturn sl2. It's a 188 thermostat.
Today about 70 degrees the car was running down the highway 70-75 mph and the scanner is reading between 172-183. Then pulling into the store the car was at 172
As soon as I parked i grabbed both hoses. The lower hose (hose with the thermostat) was warm but the top hose was so hot you couldn't hold it. A pretty noticeable temp difference between the two hoses.
The car sitting quickly went up to 190 and the lower hose started to get Warmer. It seems like running down the road it isn't warming up enough to open the stat.
What gives? I don't understand an over cooling position. I mean how can it be cooler than the t stats opening temp range. Any ideas?
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3127837 - 09/17/13 05:54 PM Re: Temp issues again [Re: ram_man]
Clevy Offline
Loc: Saskatoon canada
T-stat in backwards?
2006 Charger RT
Miles x 2 per oil filter
#3127850 - 09/17/13 06:09 PM Re: Temp issues again [Re: ram_man]
ram_man Offline
Loc: southern mo
You can't put these in backwards .
#3127852 - 09/17/13 06:10 PM Re: Temp issues again [Re: ram_man]
Warstud Offline
Loc: MIchigan
The upper rad hose will be hotter than the lower rad hose. The heat transfers from the engine to the coolant thru the upper hose to the radiator. Once in the radiator the coolant transfers heat to the fins and exits out the lower hose.
#3127864 - 09/17/13 06:19 PM Re: Temp issues again [Re: ram_man]
spasm3 Offline
Loc: out there
177-183, I don't think you have a problem. Thermostats do not regulate temperature that precisely. If its within 10 degress, i'd be okay with it. Running down the road, its a small engine , aluminum block and cools easily.
13 elantra 39k 5w30 ultra
03 chevy avalanche64k pyb
02 saturnsc1 62k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 71k 5w30mc5k
#3127886 - 09/17/13 06:41 PM Re: Temp issues again [Re: ram_man]
Boomer Offline
Loc: Pennsylvania
That temp difference is why upper hoses often fail long before the lower hose.
2003 Saturn L 300 125,700 miles
2013 VW Passat TDI SE, 29,500
2014 VW Jetta TDI SportWagen 14,000 miles
#3127894 - 09/17/13 06:49 PM Re: Temp issues again [Re: ram_man]
Errtt Offline
Loc: California
I've had new stats that didn't work well.
Is 188 the recommended stat?
Also keep in mind the coolant needs enough time in the radiator to cool. I've seen folks remove the stat and it worked out well, while some had the coolant pass through the radiator to fast and caused problems. Water pump impeller condition, rad core etc.
It needs flow but also need time in the rad to cool too.
Many will buy & use OEM stats to try and avoid problems.
I also like to replace the rad cap (and clean the fill neck) when I do a stat job.
Edited by Errtt (09/17/13 06:57 PM)
#3127906 - 09/17/13 07:01 PM Re: Temp issues again [Re: spasm3]
JHZR2 Offline
Loc: New Jersey
I'd say this is probably the right point. IIRC the OBD reading on our "cooler" cars is 182-ish in the heat of the summertime. So 177 is probably within the realm of correct.
Ive heard many times that folks should test a t-stat in a pot of water first to ensure it opens at the right temp and correctly. Apparently there are many duds. Its only because good due dilligence is being done here that we are even talking about it.
#3127985 - 09/17/13 08:06 PM Re: Temp issues again [Re: ram_man]
MONKEYMAN Offline
Loc: St. Louis
Where is your temp gauge after thermostat replacement? Should be 1/8 inch or so to right of the quarter mark. Two OEM and one Stant in my Saturn put temp gauge in that general area when engine was warm.
Truth alone triumphs, not untruth.
#3128072 - 09/17/13 09:07 PM Re: Temp issues again [Re: ram_man]
ram_man Offline
Loc: southern mo
It's always right above the 1/4 mark by maybe one needle thickness. Sometimes it's almost on the 1/4 mark.
Call me crazy but how can 172 be ok? That's Almost 20 degrees off. Another thing I noticed is the long term fuel trim are around -4 they used to be -16 - -18
My gas mileage is averaging. 29 and it used to avg 33 or so.
#3128073 - 09/17/13 09:09 PM Re: Temp issues again [Re: ram_man]
TechnoLoGs Offline
Loc: Call it NNJ
Head gasket?
I'm serious.. any signs other than temp difference? (Can say a lot)
1993 Chevrolet S-10 Blazer 4.3, the Frankenblazer - 184,440mi. 10/22/13 - WPP Supertech 10W-40
12,359 10/22 12,361 10/23 12,365 10/24 12,369 10/25
#3128081 - 09/17/13 09:13 PM Re: Temp issues again [Re: ram_man]
ram_man Offline
Loc: southern mo
Nope the car is rock solid. Honesty I'm wondering kind of a stretch but maybe the radiator and water pump both are newer are improved over the originals and offer better flowing characteristics. My honda does not fluctuate more than 4 degrees the Saturn is 10-12 degree swings. It's weird.
#3128137 - 09/17/13 10:16 PM Re: Temp issues again [Re: ram_man]
The_Eric Offline
Loc: Iowa
Did you use an OE stat?
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#3128162 - 09/17/13 10:57 PM Re: Temp issues again [Re: ram_man]
ram_man Offline
Loc: southern mo
Used a napa the local gm dealer couldn't get the gm stat for it.
#3128279 - 09/18/13 06:27 AM Re: Temp issues again [Re: ram_man]
meep Offline
Loc: Southeast
ever tested a stat? they are supposed to be fully open at the rated temp. they start to crack open before.
being that the cold hose was still cold, it sounds like it was just cracked open, letting small flow through.
i think this is ok. if you had a bigger load on the engine, the temps would creep up some more.
also, as stated above, I would totally understand being off by a few degrees, too. these systems are not "precision."
2006 Tundra 2wd
2002 MDX (wifey!)
2005 s60 2.4L
Page 1 of 3 1 2 3 >
