Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
Carlson Slide Pins
by SavagePatch
08/27/16 08:07 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
53 registered (3800Series, B320i, Billbert, 69GTX, Astro14, 901Memphis, 6 invisible), 946 Guests and 33 Spiders online.
58943 Members
66 Forums
253655 Topics
#3123260 - 09/13/13 01:37 AM replacing ac system
SuzukiGoat Offline
Loc: Louisiana
A deer horn went through my condensor fan and condensor, don't ask.Gonna get the insurance company to take care of that aspect, but my compressor wad already out do to an overcharge.What all should I order and replace myself before bringing it to the shop for them to replace the condensor and fan. What needs to be replaced because of the hole in the condensor, and what should I replace on my own dime?Appreciate any help.Thanks
1995 Suzuki Sidekick Auto 4x4 on 33s. Low mileage motor in 200k body. Denso with M1 0w40.
1996 Geo Tracker Auto 4x4 Denso VNG 10w30. 120k.
#3123315 - 09/13/13 04:48 AM Re: replacing ac system [Re: SuzukiGoat]
Roadkingnc Offline
Loc: NC USA
If the compressor is locked up you need to flush the system replace the orifice tube or expansion valve, accumulator or receiver drier. Make sure to add the right amount and proper type of oil.
If its not locked up just replace the compressor and add the proper amount of oil for the compressor and condenser
#3123322 - 09/13/13 05:17 AM Re: replacing ac system [Re: SuzukiGoat]
MarkM66 Offline
Loc: stl
Need to replace the whole system; compressor, condensor, drier, orifice tube, flush lines, vac, charge.
#3123372 - 09/13/13 06:58 AM Re: replacing ac system [Re: MarkM66]
Donald Offline
Loc: Upstate NY
This.
Have the shop deal with the oil and freon. Maybe add leak detector from the start. Replace any o-rings that can be gotten to easily.
How did the system get an overcharge? If a shop did it, do not go back there. The shop should fill it by weight.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3123452 - 09/13/13 07:58 AM Re: replacing ac system [Re: SuzukiGoat]
SuzukiGoat Offline
Loc: Louisiana
The previous owner in another state filled to Max pressure according to this [censored] DIY guages. The problem...it was the coldest day in like ten years in Mississippi.
Soon as the temps warmed the compressor croaked.
Still no leaks though. Was holding MASSIVE pressure for over a year, and still is holding the correct amount.
Or was, don't know what all is now broken.
So the consensus is replace everything.
Well the only other thing is, what to make the insurance company pay for and what should I buy?
Without question they are buying the damaged condenser and fan. What else.. don't want them to pay for anything that a horn through the condenser wouldn't damage.
Obviously I want to pay for the compressor, blower. Ill install everything and have the shop do the oil flush and refill?
#3123552 - 09/13/13 09:27 AM Re: replacing ac system [Re: SuzukiGoat]
MarkM66 Offline
Loc: stl
Do the math. Insurance would pay for the condenser and fan, as they were damaged in the accident. Even though the condenser would of had to be replace anyway if the compressor was bad.
You pay for everything else. crazy
#3127104 - 09/16/13 10:42 PM Re: replacing ac system [Re: SuzukiGoat]
SuzukiGoat Offline
Loc: Louisiana
So literally everything is on the way...
Can I disconnect all the lines, blow them out with 120psi of air, reconnect everything, bring to a shop for flush and fill?
What about the oil?
#3128057 - 09/17/13 09:02 PM Re: replacing ac system [Re: SuzukiGoat]
artificialist Offline
Loc: Florida
What about the oil?
The service manual will tell you how much refrigerant oil to put in each AC component. Also see what viscosity of refrigerant oil is correct. Sometimes replacement compressors already have refrigerant oil inside of them.
2010 Lancer Ralliart Sportback
